BlueEyesGT
Drives: Polo 1.2 TSi
Post by BlueEyesGT »
ciclo wrote:Hi sheFs,
Ok, the set of harnesses (right and left) for RHD taillights 6C I will do for you.
I have yet to receive the parts, I guess this week.
http://partsale.eu/spare-parts
RHD
http://partsale.eu/spare-parts/view/VOL ... J-75024785
http://partsale.eu/spare-parts/view/VOL ... J-75024789
You have to enter your post code when clicking to cart to get price with shipping cost.
Price: 150 € +/-
Other site: http://www.carparts-pros.com/index.php
Hello,
I am retrofitting Polo 6R tail lights to my new Polo 6C (yes, exactly opposite of what you have done :) ) Now, I am looking for adapters as I hate to slice the stock cables. I found ready to plug 6C adapter here but I am trying to source the adapters and get the wiring done myself. Could you please help me out with part number of the mating connector for 6C,thanks.
CNK
Drives: 6R
Post by CNK »
BlueEyesGT wrote:Hello,
Why you do it? :o
BlueEyesGT
I was expecting this question :lol:
Polos sold here have very un-inspiring tail lights. They are nowhere close to Polo 6C tail lamps sold around Europe. Luckily, I have got my hands on brand new 6R lights at through away price, so why not.
I am now aware of an OEM part of VW that does that. X2car.de has some non-OEM connectors too, for example for their interpretation of ciclos auto-light wiring they have a mating connector for the 17-pin plug for the light switch.
What I maybe can recommend:
- extract the female terminals from the 1S0 972 706 (
- take a 535 972 723 A for putting in the female connectors
- matching 535 972 733 for the adapter wire and male terminals
and
http://www.passatplus.de/umbauteile/stecker/stecker.htm
all contacts are "micro timer" or "micro power timer" contacts
and the other side will be the 1J0972706 with the standard power timer female
BlueEyesGT
iichel wrote: What I maybe can recommend:
Thanks for all the pointers.
I was more hoping like source male and female connectors and solder cables to the right pins. I will take this up in coming days, appreciate your response.
let's see, maybe the Master Himself has a better idea.
gpeixoto109
Drives: 2013 Polo 6R 1.2TDI
Post by gpeixoto109 »
ciclo wrote:Some time ago many People have asked me to do a guide on how to install the automatic lights "OEM" on Polo 6R without factory xenon and non Bluemotion in easy way.
Polo 6R. Automatic lights OEM with halogen headlights, non BlueMotion.
From now, in all Polo 6R model (Europe) can be installed automatic lights OEM " in an easier way ".
As this guide is set for Original Equipment (BCM) it is a breakthrough to facilitate the installation of original xenon headlights. In this case additional modifications in original wiring are required.
Hi Ciclo! Thank you for all your help with the process for installing the Automatic Lights on my polo! :D
All the process was very good, you helped me a lot, and I think the money was worth. Once again thank you!
And here is the result:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZEY0xxxxx
56-Radio -- Status: OK 0000
Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 AJ    HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H10 3316
   Revision: 11002002    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TDI03103P906021AJ 001005
   ROD: EV_ECM12TDI03103P906021AJ_VW25.rod
   VCID: 70EF364BAB56C89E643-8025
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2485412600C48415246F825300420905
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_AU21.rod
   VCID: 8F2DD5B756A837669D9-80DA
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 3979CB6FB0AC49D693D-806C
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 089 F    HW: 7H0 937 089
   Component: BCM T5GP Li4  H50 0254
   Revision: BS050001    Serial number: 0465 124120377
   Coding: 7DB02FB80821020001380EB06CEB8ED85F80612F60862001200000010000
   Shop #: WSC 00233 572 91226
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 050512 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD
   Component: J387__TSG_BT  008 1611
   Coding: 18BC30
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01S7TUI
   Coding: 00314D
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4A9B84A3ED4AD24E0A7-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB400I50HLEGGP$
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB405522BUKA946
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB401A50J2EM8RJ
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB401850J2EBQ75
   Part No SW: 6R0 920 861 M    HW: 6R0 920 861 M
   Component: KOMBI         H02 0406
   Serial number: 00000017018511
   Coding: 140A01
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
   ROD: EV_DashBoardUDSJCIPQ25_VN81.rod
   VCID: 3F8DA577A68867E6AD9-806A
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 H50 0254
   Revision: BS050001
   Coding: 002200
   VCID: F0EFB64B2356489EE43-80A5
Address 25: Immobilizer (J285)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H02 0025
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
   ROD: EV_ImmobUDSJCIPQ25_SK25.rod
   VCID: EADBA4230D8AB24EAA7-80BF
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11220
   Shop #: WSC 00788
   VCID: 306FF64BF7D6889E243-8065
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 56D 035 190 A    HW: 56D 035 190 A
   Component: RCD510USBRVC  002 0003
   Revision: -----001    Serial number: VWZ4Z3P8180129
   Coding: 0100022501000B
   Shop #: WSC 00078 790 00188
   VCID: 224B0C033D3A2A0EA27-8077
End   ---------------------------------------------------------------------
No errors! Perfect wiring :)
And a video of CH/LH working :mrgreen:
Very grateful for your comments gpeixoto109.
Good improvement with original parts, BCM Max, license plate with LED lights OEM, light-rain sensor, anti-dazzling mirror, automatic lights with CH/LH, etc...Image
You know will have my assistance whenever you need. You are a great person.
wamba
Drives: polo 1.2tsi
Post by wamba »
hi ciclo
you know if it is possible to add a gateway on our polo
as you know except the blue GT and bluemotion has a gateway separately
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
To everyone who wants to upgrade your polo 6R.
I have new max BCM units 7E0937090. For details: viewtopic.php?f=62&t=67921&p=507030#p507030
Yes but I'm not really sure what wamba wants. He probably has a Polo with an internal gateway in the BCM. Adding a second one isn't really going to help anything, it will only not-work and add some problems.
wamba
Drives: polo 1.2tsi
Post by wamba »
I asked this question because I want to use this box, which must be connected to gatewaye
http://www.auto-polar.com/products/polarfis-advanced/
Are you sure that works on Polo 6R, since it's not really in the support-list?
wamba
Drives: polo 1.2tsi
Post by wamba »
yes, it's work with bluemotion and blueGT
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
iichel is right about this. There is no separate gateway in a Blue GT. And it can not be "after" installed. And you can not connect the Polar-Fis without a gateway which Auto-Polar has confirmed in an e-mail to me.
Locked
