Thanks for the pointer.
I've not fitted the stalk yet, but trying to gather required info in terms of wiring required. My VCDS autoscan results are as below -
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40893042D3F4A91EDBD-8015
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 K HW: 6RU 937 087
Component: BCM IM H+4 H35 0424
Revision: BZ035001 Serial number: 9700 019146673
Coding: 3A904ABF08A10000003800002C0B04900040414F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 6ADDB2EA8508834E259-803F
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5520
Coding: 010000
My polo BCM is 6R0 937 087 H as seen on VCDS.
Will I be able to retrofit cruise control with this BCM please?
I read that some BCM ending with 087 doesn't have the pind for cruise control.
I don't want to invest in cable, switch , time and money, if it not possible with this BCM.
sendoc wrote:My polo BCM is 6R0 937 087 H as seen on VCDS.
It might be possible that you are able to retrofit cruise control on your 6R... (sorry, I'm always joking around)... at least your BCM 6R0 937 087 H supports this function.
Is not the same, however to buy stalks (used) and install CCS in your car, either of the two is good.
521 with ring, full set from factory.
507 without ring
Ring
6R0959653 to models without ESP
6R0959654 to models with ESP, static cornering lights .
ciclo wrote:Is not the same, however to buy stalks (used) and install CCS in your car, either of the two is good.
507 without ring
Ring
Thanks ciclo! I didn't know that there are so many versions of stalks
