boot light
adam_0612
boot light
Post by adam_0612 »
my boot light keeps coming on, on my dashboard and it is really annoying
me and my m8 had a quick look around in a car park in the dark and couldnt find anything but obviously wasnt the best of looks.
any ideas what it could be?
or have any of you had the problem b4?
Post by 8080 »
Loose hose for rear window washer caused that in my car. The lock got wet. V. common
bouzel
Post by bouzel »
i got the same problem as well as the boot light doesn't come on when you open boot bit annoying when your looking for something in the boot
new lock?
many thanks
Anis
adam_0612
Post by adam_0612 »
i meant the boot light on the dashboard, telling me that i haven't shut my boot when i actaully have
madmatt
Moderator
Post by madmatt »
need the tailgate stripping down and hose reconected .
you might just wanna clean the wire counecters too use either wd40 or a contact cleaner
on the unlucky side you might need the termals replacing as they have a tendancy of breaking when they been corroded for a while and you my need a new boot lock
this is commen on the full vw range ive repaird 2 just today normaly caused by trying the washer jet when the jet is frozen the preasure builds up and pop gos the pipe
other commen places on a polo is just behind the abs pump
the genuine vw repair procedure is the connecters cut off the pipe ends and rejoined with small bore rubber pipe and secured with crimp clips
Tim_GTi
Post Whore
Post by Tim_GTi »
yeh there's loads of coverage on this on the site, just give it a search
the ultimate solution (as i always say!)
de-rear wiper 8)
adam_0612
Post by adam_0612 »
thanks for your help evry1. i wil give it a better look at 2morow when it isnt pouring down with rain, hopefully.
also when you got rid of your rear wiper did you just fill it in with a bung?
Tim_GTi
Post Whore
Post by Tim_GTi »
Used a 50p grommet from halfords, and applied silicone sealant around the edge on the inside
8)
Mouse_GTI
Post by Mouse_GTI »
You will probably have to replaced the switch. Mine is knackered again, happened the exact same time last year :roll:
joejs90
Post by joejs90 »
you dont have to replace the full boot lock.. t6here is a little switch in their you can get them from about £2 form the scrapper they were alot more a vw...
