Phil's Fabia vRS
- pip_polo
Re: Phil's Fabia vRS
The pics were not up because i've not been on the computer, been using the iphone and it's way to much effort to do stuff like that.. so..
heres the pics.. going to go out later and get a few as i've also sorted my HID's so they work and point where they should.
Getting started..
Drivers front done..
Rear springs in..
EGR delete that i've not taken a pic of before..
- Tim_GTi
- Post Whore
Nice work, do those side strips come off?
- pip_polo
yeah, but aloy of fabias tent to have bubbled paint under them..
- Tim_GTi
- Post Whore
Looks sick! what wheels are they?
- pip_polo
Boring TT comps
- Tim_GTi
- Post Whore
They look awesome in White.
- pip_polo
- pip_polo
bit of an update, if anyone cares haha
Currently running 195bhp and 455nm torque.
Well the FMIC is now all fitted. A massive thanks to Chris at CC Tuning for been an actual leg end.
We did a before, after and another remap to see what actual gains the FMIC gave.
I've done a quick how too for Briskoda, so i'll just paste it in here.
Fitting the Seat Sport FMIC onto a Fabia vRS
So this is what a Fabia vRS looks like without a FMIC:
First things first, this is how I carried out the install and is only a guide. If you manage to kill yourself or someone else by following this.. You’ve done it wrong.
Items needed:
Seat sport FMIC
Mounting brackets
Pipe work
Tools:
Selection of different Torque screwdriver attachments. (The star shaped ones)
Selection of different sockets
Screwdrivers
Sharp knife
Angle grinder
Hammer
Get the bumper off.
In this picture I have done a yellow dot for screws, which are in the arch, on top of the bumper and underneath. The three orange dots show where there are three plastic clips, which I just cut away. The fog lights and temperature need to be disconnected too.
Take off the crash bar.
Once the bumper is off you can see the Torque screws which need to be removed. This picture shows where the screws came from and also the SMIC which is to be removed.
We decided for ease to remove the headlights, this will become clear later.
There are two torque screws and a bolt to hold the headlight in place then unclip the wiring.
The next step is to remove the old SMIC, This is held in place with a few bolts and clips, once you can see it, it’s obvious what needs to be done here. The pipes are removed using a flat screwdriver to pop off the metal clips, and then they just pull apart.
This step is different to what I have seen done before as I wanted to try and make the FMIC look as standard as possible, so I removed all the plastic which holds on the radiator etc. This is held in place with lots of torque screws and some clip things, once again it’s simple to see where the screws are once in front of you.
We test fitted the FMIC with the brackets and found it could do with been about 2mm further forward away from the radiator, so we put in some washers to space it a bit.
Once both brackets were secured in place, they bolt directly to the mounting holes of the radiator, so the same screws are used. We attached the FMIC.
Now the FMIC is in place the hard parts, or more frustrating. Cutting the black surround so that it doesn’t foul on the intercooler. This part will need to be done without guidance, as I cannot say how much/little needs removing. Just offer up the plastic and see where it fouls and cut away the plastic as you need, we used an angle grinder as it was easy.
This shows how the whole bumper bracket needs to be chopped off.
Picture of all the plastic trimmed and back together with the small FMIC snug inside
Then time for the piping, making sure it all fits. No need to tighten it all yet as it will need to come apart to see where the crash bar needs to be altered. (REMEMBER to remove the old seals from your original pipe work and fit them in the joints that connect the new pipe work to the old, I forgot and by god did the car smoke ha-ha)
We decided to remove the whole of the lip so that there was no way it could foul on the pipe work. Put some blue tap on it to show what was cut. Then tightened the crash bar back onto the car.
Then fitting the MAP sensor, this needs to be taken from your old SMIC and put onto the pipe work, I managed to get the plug to fit inside the sensor by removing a few cable clips to give me that extra inch.
Then fitting the bumper back in place and putting in the lights, the lights just bolt straight back in (make sure you clip in the wiring).
The bumper needs some of the black inner plastic removing; again I just used the angle grinder and chopped off what wasn’t needed to make sure it wasn’t touching any of the pipes.
We did a before and after rolling road to see what the difference was in having the FMIC fitted.
Before: 158bhp
After: 185bhp
Remap: 195bhp
(other modifications done too)
Will post the rolling road graph once I get an electronic version.
Items needed:
Seat sport FMIC
Mounting brackets
Pipe work
Tools:
Screwdrivers
Sharp knife
Angle grinder
Hammer
Get the bumper off.
Before: 158bhp
After: 185bhp
Remap: 195bhp
- pip_polo
Got bored of cleaning the tt comps, so sprayed my standards black and put them on. got some special wheels for next year
Not much room witht he brakes
- Tim_GTi
- Post Whore
I love this! Purely because I am very close to packing up shop and getting one.
Looking great mate.
how much was the FMIC kit? And what's your suspension setup? (what kit and how low?).
Looking great mate.
- pip_polo
Hey up Tim. Not spoken in a while, catch me when am on facebook sometime.
The suspension is Weitec Hicon GT coilovers, lowered about 60mm i would say. They can still go down alot though. Just my engine tray catches on the road as it is. With these 312mm brakes i can make my spliter touch the floor haha.
FMIC is a seat sport one, so can be picked up cheap secondhand from the ibiza cupra. I paid £250 for it brand new from Sere motors in Ireland, which included the mounting brackets. (seat uk want about £320 for it). Then i got the forge pipework which came to around £230. So all in cost me about £500 then a rolling road and a tweak of my map.
- Tim_GTi
- Post Whore
Will do mate. All sounds great. My polo is wayy too unpractical for the amount of long journeys I'm doing nowadays, I need something cheaper to run, more practical and faster
- pip_polo
sounds like the vrs is a good option then.. £7k?
