I have a 2001 Polo GTi and when I started it earlier today the Check light came on the dash. I had just checked the oil etc levels and they were fine. As I was going to an emergancy I carried on and realised that the car was making a loud noise when it was being driven and when I put my foot down on the excelerator.
When I got back I noticed that the car was sounding a bit tappy so had a look under the bonnet when it had cooled down and took off the engine cover and the cambelt cover. This is when some plastic curved bit fell out onto the floor. They were obviously once together looking at the breakages but I'm not sure where they are from. I know that the tensioners can fail and was wondering whether this has happened?
The cambelt was last changed 24,000 miles ago. If the tensioners have gone, will this have caused the belt to slip and damage the valves? I haven't started the car since and have just pushed it to the back of my drive. Typical seeing as though I am trying to sell it!!
Any help would be appreciated!
Cambelt Problems?
Re: Cambelt Problems?
That sounds like the main cambelt tensioner if if came from underneath the cover.
DO NOT DRIVE IT
You MUST get the cambelt changed as soon as possible. The belt hasnt come off yet so you are ok. Just keep it out of gear if you are going to move it or otherwise, and get the belt and tensioners changed as soon as!
DO NOT DRIVE IT
I thought as much. What does the main tensioner actually look like as it was two pieces of curved plastic that formed a semi circle that fell out. Does that sounds like a tensioner?
Don't worry as soon as I saw the pieces I haven't started it and not going to
Surely jf the cambelt was replaced only 24,000 ago (2 1/2 years ago) they shouldn't be failing. Would this also explain the check light and the louder noise when I drove it?
Thanks for your help anyway
- Drives: 6N2 Polo GTi & 9N3 Polo GTi
It would explain the 'engine check light' yep.
Did you use a genuine VW cambelt kit when it was changed last time?
I'm not sure what kit was used as it was changed before I bought it. I have the receipt and it just states Cambelt Kit and not what make.
How much am I roughly looking at now to get a new kit fitted?
My cambelt kit cost me £90 approx. from GSF..
VW quoted me £330 all in in 2009.
Yes it would. Its a round tensioner wheel, with two lips either side - thats what you have found snapped off
It would explain the louder running, as the belt isnt running true
It it was a cheap kit and non genuine, it could well fail.
When replacing bits like that, I would always recommend using genuine VW parts - a new cambelt kit and waterpump from a dealer is about £160. From TPS about £130
Thanks for your help guys.
Atm I'm in two minds about what to do. I am trying the sell the car, but as it is a previous cat c I haven't had much interest. It might be more viable to break the car. Do you have any idea about how much I could get back should I decide to break the car, considering the engine will need a cambelt?
I don't want to break it but I also don't want to throw more money at it and not get anything back at all.
What is the current milage on the car? I'd assume is must be pretty low?Lytescary wrote:Thanks for your help guys.
If it's the same paint code as my silver GTi, I'd take a load of body panels off of ya and other bits and pieces as you're not too far away from me!
Thats if you do decide to break it!
You'd probably get decent money for the gear box and rims alone (providing they are in nick) so worth considering!
It's on average miles at 95,000 so not low at all. How come you presumed it was low?PD wrote:What is the current milage on the car? I'd assume is must be pretty low?
What panels do you need mate as I have a spare driver's door in silver sat in the shed. And the gearbox was reconned a year ago so yeah I should get good money if I do decide to break it. I'll bear you in mind should it come to that.
Sorry, I read your first post as; the cambelt was changed at 24,000 miles two and a half years ago. thats why i assumed the milage was low! My bad!!Lytescary wrote:It's on average miles at 95,000 so not low at all. How come you presumed it was low?PD wrote:What is the current milage on the car? I'd assume is must be pretty low?
I am after passengers side front wing, rear bumper, boot, rear wiper motor, rear cross member, radiator fan and a few interior bits and pieces possibly.
Let me know what you decide to do. I'd be inclined to fix it but if your having issues selling with it being a Cat C then breaking is a good alternative.
