I have 1.9TDI polo, I want to lower it so it has a nice stance? i was thinking 30mm?
can someone post pics of there polo's or recommend some suspension?
also lowering springs? coilovers? im not 100% sure what to do!
Lowering my 9N3 POLO
Re: Lowering my 9N3 POLO
Lowering 30mm on a polo Is pointless as the arch is so big
Go for coilies then you can choose the height
Disagree. Mine on 35mm wasnt a bad height.
TomG wrote:Disagree. Mine on 35mm wasnt a bad height.
The arch seems to measure about 50mm and that's on a gti which is lower from factory
The 15-20mm wouldn't make much difference to me.
Needs to be at least down another 30/40mm imo to look smart
I got h&r 35mm lowering springs for gti so should be abit lower than a standard polo
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
If your lowering more than 30/40 i recommend you get coilies instead.
I had 50mm on my standard shocks and the ride...well, no one would sit in my car
- whitegtipolo
get coilovers you will never be happy with springs
