POLO 6R. HEATED SEATS. OEM.
Posted: Mon Jan 12, 2015 5:44 am
"This information will be continually updated"
Current flow diagrams
Onboard supply control unit, Heated front seats control unit
J519 - Onboard supply control unit
J774 - Heated front seats control unit
SB37 - Fuse 37 on fuse holder
T16n - 16-pin connector
T73a - 73-pin connector
T73b - 73-pin connector
96 - Earth connection 1, in seat heating wiring harness
199 - Earth connection 3, in dash panel wiring harness
606 - Earth point, under the centre console near gear stick
A4 - Positive connection (58b), in dash panel wiring harness
A21 - Connection (86s), in dash panel wiring harness
A141 - Positive connection 2 (58b), in dash panel wiring harness
Heated driver seat regulator, Heated front seats control unit, Heated seat cushion for driver seat, Heated backrest for driver seat
E94 - Heated driver seat regulator
L44 - Seat heating switch illumination bulb
T2eg - 2-pin connector
T2eh - 2-pin connector
T6ac - 6-pin connector
Z6 - Heated seat cushion for driver seat
Z7 - Heated backrest for driver seat
110 - Earth connection 2, in dash panel wiring harness
238 - Earth connection 1, in interior wiring harness
439 - Earth connection 3, in dash panel wiring harness
605 - Earth point, on top end of steering column
Heated front passenger seat regulator, Heated front seats control unit, Heated seat cushion for front passenger seat, Heated backrest for front passenger seat
E95 - Heated front passenger seat regulator
T2ei - 2-pin connector
T2ej - 2-pin connector
T6ad - 6-pin connector
Z8 - Heated seat cushion for front passenger seat
Z9 - Heated backrest for front passenger seat
Info
It is advisable to read the whole topic but in this link you will find very good information.
http://www.uk-polos.net/viewtopic.php?f ... 11#p520897
Notes
Removing and installing front seat (cushion cover and padding, backrest cover and padding)
Disconnect vehicle battery
WARNING
Electrostatic discharges may result in unintentional triggering of airbag. Therefore, the mechanic must electrostatically discharge him/herself before disconnecting the igniter and earth wires. This can be done by briefly touching the body or striker plate of the door.
cushion, backrest
WARNING
If the front passenger seat cushion padding is renewed, the seat occupied sensor, front passenger side -G128- must also always be renewed
Notes
In the seat padding in vehicles with a seat heater is renewed, the heating element is also to be renewed.
Assure a dust free adhesive area on the padding.
Bond heater element fold-free to padding.
Links to buy
Cable set http://www.kufatec.de/shop/en/volkswage ... t-ibiza-6j
Note: It is necessary to consider whether the onboard power supply control part can encode on seats
Info
Notes
WARNING
cushion, backrest
WARNING
Notes
Links to buy
