This feature only can be enabled for first year of production of Polo 6R.
The solution to get this feature on Polo 6R (since Nov 09) is to run a wire from T4e/1 brake switch connector (splicing to the existing wire) to BCM white connector T73b/42 (check before if your BCM has this pin).
Brake switch connector is beside the brake master cylinder (engine bay).
RHD T4e, grey connector on image
LHD T4e, C on image
Also you must activate Byte 12 bit4 on BCM, Address 09 Cent. Elect.
... if you do it please tell us your results.
