Hi All,
For some reason the interior lights in my polo have decided to stop working.
When they stopped working there was a loud relay type click from by the pedals, naturally i checked and changed the fuse, however, the lights still don't work!
Any ideas?
Interior Light Failure
- Drives: Lowered Polo 6R
Re: Interior Light Failure
Those are the exact symptoms of a blown fuse. Are you sure you changed Fuse 21 (10A)? Might be worth checking your exterior lighting as well, as often them blow in conjunction with each other, in which case its usually a 15A fuse in 43
