Starter clicks twice then nothing after coil pack failure
Posted: Sun Nov 10, 2019 5:04 pm
Got a fun one.
2001 gti, manual.
It had an electrical issue with the coil pack, basically it shorted internally it seems and started to melt some of the earth wire from the coil pack plug.
It damaged 3 of the plugs in the loom where the earth runs back to the chassis, the plug on the actual coil pack and both the male and female plugs down above the gear box.
Earth wire changed, new plugs fitted, and a new coil pack (turns out the old one had a big crack across the body of it)
Did all that and then the starter relay just clicked... no cranking, then on the next try of the key nothing.
Left it for a while and few days later it did a couple of clicks and that was it.
Checked and there was 12V to the starter on the main cable and 12V going to the single plug on the starter solenoid.
Thought maybe the starter was toast as the car was cranked for a few mins as it wouldn’t start when the coil pack was busy melting the wires and it’s self (had the other half known then she wouldn’t have been cranking it over).
Finally got a new starter on it, and same thing, couple of clicks then dead.
There is an alternator fault when I scan it and the battery light is flashing, but I would still expect it crank over?
Any ideas? Ready to call it quits if honest...
2001 gti, manual.
