VW Polo 1.6TDI starter relay problems
Jukums
Drives: 6R
Post by Jukums »
Hello,
Have issue with my VW Polo 1.6TDI 2011 year.
Was randomly driving, when suddenly get christmas tree in the instrument cluster for many errors. After stoping and trying reset engine, it wasn't starting, so starter wasnt working, but when i pushed car, it will start but doesnt work power steering.
Below attached scan for whole car. I alreeady checked all relays, fuses and wiring near car batterry and below it, but problem still remains. Maybe somone had this issue ? Can it be BCM module or something else ?
Monday,16,August,2021,20:27:28:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBY241146 License Plate:
Mileage: 195540km-121502mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 61
VIN: WVWZZZ6RZBY241146 Mileage: 195540km-121502miles
03-ABS Brakes -- Status: Sporadic communication error 1000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 ME HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9970
Revision: --H33--- Serial number:
Coding: 00114016002401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023ME 003011
ROD: EV_ECM16TDI02103L906023PL_SK25.rod
VCID: 75E154D3D4C13F2E28-8020
3 Faults Found:
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 195543 km
Date: 2021.08.16
Time: 00:24:06
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 23 °C
Intake air temperature: 23 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.972 V
Engine speed: 0 /min
Battery voltage: 12.0 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
10454 - Output for Starter Relay
P0616 00 [165] - Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 195543 km
Date: 2021.08.16
Time: 00:24:06
Status of starter activation-FRF_ST_RL: 1
Sensor for engine block temperature: raw value-Coolant temperature: 23 °C
Number of resets of main unit-CTR_RST_MC: 0
10458 - Control Circuit for Starter Relay 2
P3048 00 [165] - Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 195543 km
Date: 2021.08.16
Time: 00:24:06
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417100B3842614E682D700521300
VCID: 071D2E1BB22D3DBE4A-8052
Part No SW: 6R0 907 044 E HW: 6R0 907 044 E
Component: Climatronic H09 0609
Revision: V0000000
VCID: 356194D39C417F2EE8-8060
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 195543 km
Time Indication: 0
Date: 2016.01.07
Time: 00:24:60
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 049111064
Coding: 3CB029BF48A10000212009B07CAB0ED0DF8061FF7E860041200000000000
Shop #: WSC 124697 483 00190
VCID: 3F8DF6FBAE7DB57E32-806A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 170211 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1621
Serial number: KU0-KU004.02.1113297
Coding: 48BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1621
Serial number: KU0-KU003.02.1111440
Coding: 48BC30
1 Fault Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 195543 km
Time Indication: 0
Date: 2016.01.07
Time: 00:25:22
Component: VW10Airbag01K H09 0020
Revision: -------- Serial number: 003GX00FK0GH
Coding: 00314B
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D695-801E
Serial number: 3575HRB40570C15I7PJ6
Serial number: 3585HRB40690C15IDH9+
Serial number: 3515RRB405P09U26191%
Serial number: 3525RRB405R09U26H94L
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H04 0304
Coding: 140A00
Shop #: WSC 54321 666 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 387F9DE783538246F3-806C
2 Faults Found:
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Fault Priority: 2
Fault Frequency: 1
Reset counter: 188
Mileage: 195543 km
Date: 2021.08.16
Time: 00:25:59
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 188
Mileage: 195543 km
Date: 2021.08.16
Time: 00:25:59
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 110211F1002394
Coding: 2500C0
Shop #: WSC 00000 000 00000
VCID: 3365AACB9235611EC6-8066
2 Faults Found:
01316 - ABS Control Module
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 195543 km
Time Indication: 0
Date: 2016.01.07
Time: 00:00:12
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 195489 km
Time Indication: 0
Date: 2016.01.07
Time: 09:00:57
Component: IMMO H04 0304
Serial number:
VCID: 6ADB77AF8D7FE0D6B5-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669387837
Coding: 020000
VCID: 285F4DA75BF312C663-807C
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 195543 km
Time Indication: 0
Date: 2016.01.07
Time: 00:06:20
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: 74E769D7D7BB26261F-8020
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Serial number: 00000000009370526392
End-------------------------(Elapsed Time: 02:18)--------------------------
Re: VW Polo 1.6TDI starter relay problems
Check fuse 26 below dashboard please
Jukums
Drives: 6R
Post by Jukums »
iichel wrote: Tue Aug 17, 2021 4:02 pm Check fuse 26 below dashboard please
Wow, checked, changed it, all started to work, but after first start up it already blowed. Why ? There is 7.5A fuse, maybe there is supposed to be bigger ?
No, 7,5A is fine. There is a short circuit somewhere. Disconnect air mass meter, oil temperature sensor and power steering pump and try again.
Jukums
Drives: 6R
Post by Jukums »
Disconnected MAF, no changes, disconnected oil level sensor and now doesn’t blow. So needs to replace oil level sensor ? Wires seems fine near oil level sensor
Would be my suggestion yes
