Hello Dear Friends.
I am looking for help. I was drive home today's evening home and then EPC light appeared on dashbord and engine started to lose power.
I tried to push accelerator pedal , but there was no reaction. The car was slowing down. I had to pull over and stop the engine.
I turned ignition off, waited a few minutes and turn engine back on.
After this I could continue driving home withot problems.
Does anybody know what could happened, why it came on and disappeared when engine went off?
I am sending VCDS scan which I made come back home.
My car has engine 1,2 12V
Thank you
Monday,21,February,2022,18:09:57:00009
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: VSSZZZ6JZDR146143 License Plate: 13D13398
Mileage: 137450km-85407mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR146143 Mileage: 137450km-85407miles
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CGPA) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 E HW: 03E 906 019 E
Component: SIMOS11.1 H03 9802
Revision: --H03--- Serial number:
Coding: 00110010000400080000
Shop #: WSC 00049 770 00139
ASAM Dataset: EV_ECM12MPI02103E906019E 001007
ROD: EV_ECM12MPI02103E906019AC.rod
VCID: 2643439F59E704B651-8072
2 Faults Found:
6350 - Cylinder 1
P0301 00 [096] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 137412 km
Date: 2022.02.21
Time: 17:13:23
Engine speed: 3345.00 /min
Normed load value: 69.8 %
Vehicle speed: 119 km/h
Coolant temperature: 87 °C
Intake air temperature: 14 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.421 V
Number of cylinder 1 misfires in drive cycle-Misfires cylinder 1 from engine start to engine stop: 24
Misfire detection: counter in driving cycle-CTR_MIS_TOT_DC: 39
Misfire sum counter: carb A-MIS_SUM_A: 0
Misfire sum counter-Misfires all cylinders per 1000 rpm: 18
11836 - Cylinder Disabling
P130A 00 [096] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 137412 km
Date: 2022.02.21
Time: 17:13:24
Engine speed: 3325.00 /min
Normed load value: 43.5 %
Vehicle speed: 118 km/h
Time since engine start: 443 s
Engine torque: 60.43750 Nm
Accelerator pedal travel-Accelerator position: 47.56 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 25.125 °
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 AQ HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 10DD247D212700C60815246D845400000000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D111C33DC5157EE70-8058
1 Fault Found:
0909 - Please Check Fault Codes in Engine Control Module
U101F 00 [008] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 137412 km
Date: 2022.02.21
Time: 17:13:24
Component: LENKW.SENSOR H06 0070
Serial number: 02011304651348
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7679-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 136637 km
Date: 2022.01.05
Time: 16:39:06
Voltage terminal 15: 11.40 V
Voltage terminal 30: 11.60 V
Terminal 15 status: On
Part No SW: 6R0 937 087 M HW: 6R0 937 087
Component: BCM PQ25 H+4 H32 0407
Revision: BF032001 Serial number: 0540 011131406
Coding: 7C882BE888610100002008306C2A9C80B04042DF60880400200000020000
Shop #: WSC 12345 123 00001
VCID: 479DEE1BF6ADFDBE8A-8012
Subsystem 1 - Part No SW: 6R0 959 802 AN HW: 6R0 959 802 AN Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 5110
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 AL HW: 6R0 959 801 AL Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 5110
Coding: 020000
Component: VW10AirbagA0E H10 0020
Revision: -------- Serial number: 003GX01JBXYL
Coding: 003045
Shop #: WSC 00049 770 00112
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D695-801E
Serial number: 3495RRB400A4UPLGKHDV
Serial number: 3505RRB40184UOUINHF.
Part No SW: 6J0 920 805 HW: 6J0 920 805
Component: KOMBI H30 0202
Revision: X0030005 Serial number:
Coding: 110B22
ASAM Dataset: EV_KombiUDSMM9RM10 A04713
ROD: EV_KombiUDSMM9RM10_SE25.rod
VCID: 68DF0DA79373D2C6A3-803C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H32 0407
Revision: BF032001
Coding: 022300
VCID: 70EF65C7A3A31A06FB-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 6J0 920 805
Component: IMMO H30 0202
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADB77AF8D7FE0D6B5-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10111
Shop #: WSC 00049
VCID: 306FA5C7F7235A06BB-8064
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70EF65C763A31A06FB-8024
Part No SW: 6J0 035 156 HW: 6J0 035 156
Component: Radio H05 0012
Revision: R0000000 Serial number: SEZAZ1N6115864
Coding: 010004080203
VCID: 64C71997675BB6A68F-8030
End-------------------------(Elapsed Time: 02:21)--------------------------
Seat Ibiza 6J 2013 EPC light - engine without power
- Drives: Seat Ibiza
Re: Seat Ibiza 6J 2013 EPC light - engine without power
Please I face same problem, how you solve it?
