Rattling Vibration Noise
Casbantam
Drives: 1.2 TSI Match
Post by Casbantam »
Hello all,
Can anyone help? I have a 1.2 Polo TSI 2016 43k.
A few weeks ago I started to get a bit of an annoying rattling noise when driving slow. It sounds like plastic rattling coming from under the bonnet somewhere. Like something has worked loose? I started with just a single rattle on startup and then rattling a little as I was driving slowly in 1st gear.
It seems to have got worse since then as it seems more noticeable now more of the time. I was on the motorway yesterday and it did feel like I could feel a bit of vibration in the steering wheel and floor??
It drives fine and has just last month been serviced and passed Mot. Cam belt was changed 12 months ago.
I have hit a couple of Bad potholes recently so wonder if this could be linked?
Any help appreciated thanks.
2fast4ya
Drives: polo 1.8 tsi gti bluetec
Re: Rattling Vibration Noise
Post by 2fast4ya »
Could be a thrown wheel weight , or possible alloy damage , these will cause vibration on the steering & also make bits in the dash rattle a little , but could be damaged bushes , link rods, etc , check around all them to rule them out , check for damaged tyres , sometimes hitting potholes can cause bulges & splits on the innerside of tyres n makes vibration .& apart from that check for loose bits under the scuttle panel area ,
Casbantam
Post by Casbantam »
Cheers 2fast4ya.
I had 2 new rear tyres fitted last week so will start there I think. Maybe not balanced properly?
It's like a weird noise / vibration not easily noticeable but I can tell that it's there. I can feel the slight vibration through the floor and a little through the pedals and steering wheel.
2fast4ya
Post by 2fast4ya »
Could be that mate?
i hate the balancing weights lol i had new tyres fitted not so long ago & the wheels balanced aswel but they dont stick well or the machanics dont press them on hard enough , i heard a couple of mine come off & flung around wheels never to be seen again .
Casbantam
Post by Casbantam »
Hoping so.
Booked in tomorrow morning so hopefully will sort it out
spartacus68
Drives: 2015 1.4 TDI (90PS) Blue motion
Post by spartacus68 »
Worth having a look at the ARB links.
Brian422
Drives: 2013 Polo 1.2 Match Edition
Post by Brian422 »
Did this rattle occur immediately after service?
This may sound weird but some time ago, after removing and replacing Air Filter box, I had an annoying plastic rattling noise.
Quickly found lug on Air Filter box rear had not correctly located in rubber grommet.
Casbantam
Post by Casbantam »
Just randomly started.
Fortunately I found an earlier post from Bepis who suggested loose caps on top of the shock absorbers. Worked a treat and rattle solved.
Brian422
Post by Brian422 »
Happy to hear rattle resolved and one to look out for.
