Polo 2007 9n wipers not working
Posted: Thu Nov 02, 2023 11:26 am
by g123
Hi wipers on my polo are not working when activating the stalk. Only thing that works when I lift the stalk is the spray wash but no movement on the wipers at all. Currently wipets have been bypassed using a manual switch.
Could simply be a problem with the stalk as there are no known relays on this model relating to the wipers- thanks
Re: Polo 2007 9n wipers not working
Posted: Thu Nov 02, 2023 11:29 am
by iichel
Did you check the fuse?
Posted: Thu Nov 02, 2023 11:40 am
by g123
hello, yes first thing i did
Posted: Thu Nov 02, 2023 6:48 pm
by Maarten
Still could be a faulty handle
Posted: Thu Nov 02, 2023 8:54 pm
by g123
ordered part today arriving monday , hopefully that should work fingers crossed
Posted: Fri Nov 03, 2023 6:16 am
by Maarten
Keep us posted
Posted: Fri Nov 03, 2023 10:09 am
by g123
will do,
Posted: Thu Nov 16, 2023 6:36 pm
by g123
Hi just fitted new stalk, but now it only works on position 3 , no intermittent , no position 2 but works on 3
Posted: Thu Nov 16, 2023 6:44 pm
by Maarten
Do you have a rainsensor?
Posted: Thu Nov 16, 2023 7:19 pm
by g123
New stalk fitted, but now wipers only work on highest position, no Operation on intermittent or position 2 -any ideas for next step ?
Posted: Thu Nov 16, 2023 7:35 pm
by g123
no rain sensor on this vehicle
Posted: Fri Nov 17, 2023 8:48 am
by Maarten
Are you sure there is no broken wire?
Stalk was new?
Do you have VCDS?
Posted: Mon Dec 04, 2023 2:11 pm
by g123
Update as promised, if we don’t update non will be the wiser and everyone loses out. Wipers fully operational again. Turned out it was a relay.
Posted: Mon Dec 04, 2023 6:28 pm
by Maarten
Thanks for posting the solution.
Glad everything is working again
