Headlining Re-Trim
spudisdabest
Headlining Re-Trim
Post by spudisdabest »
First off, mine it the sunroof model, so it varies a little bit but not much.
tools needed:
Flat head screw driver
Posi drive screw driver
Heat resistant Spray Adhesive
Fabric
Fabric scissors (ordinary scissors and can be used but takes longer)
a hell of a lot of patience
Step 1:
Removes all the bits screwed through the liner. Handles, sunvisor and with mine i had to pop out the plastic surrounding for the sunroof control by simply inserting a flathead screwdriver into the front then pulling the unit down
on this picture you can see the location of the clips but the whole covers comes down if you just pull it from the front:
remove the the plug for the light
next bit is to remove the seals on the doors and boot. these simply pull off:
with the seals removed you can see into behind the pillar covers and see where the clips are holding them on. either yank em' off or get a flathead in there.
poverty spec polo:
next is the time consuming part. this is simply covering the existing with the new fabric. i did mine in sections and just pulled the fabric tight as i sprayed it on and got rid of the majority of the creases. mines not 100% perfect and there are a few bits that could be better but for my first time its bloody good :D
to put it back in just reverse the process to fetch it out!
will upload pictures of it finished tomorrow. im tempted to leave the sunvisors/grab handles/pillars grey as i cant decide how to overcome to grey sunroof cover and the contrast between grey and black at the moment works quite well!
for my fabric i used a dinner table sheet 160mmx260mm so was perfect size and cheap enough £9.99 and heavy duty spray adhesive from hobbycraft £8.99
spudisdabest
Re: Headlining Re-Trim
excuse the flash on these. but as you can see not too darn bad even if i do say so myself!
red6n2
Post by red6n2 »
id pay for you to do mine lol
spudisdabest
no thanks...was a right ball ache trimming around the control unit and the sunroof opening
justjamie
Post by justjamie »
gonna be makin a start on mine tonight.
got 6m² of black suede layin around, so gona do all the pillars in suede also, an paint the handle, switch surround etc black, an try an do something with the sunroof switch 8)
will post my progress up on here
lowfoon
Post by lowfoon »
red6n2 wrote:id pay for you to do mine lol
I'll second that
red6n2
Post by red6n2 »
see could be worth your while !
...$ching ching$...
:D
justjamie
Post by justjamie »
dependin on how mine goes, i maybe willin to do some other peoples linings.
will get the pics up when its done an see what you think 8)
lowfoon
Post by lowfoon »
justjamie wrote:dependin on how mine goes, i maybe willin to do some other peoples linings.
Deal :D
spudisdabest
got bored with the black, so is now looking like so
and because it has white in the camo, the handles, pillars and sunroof cover all blend in nicely :)
tja198a
Post by tja198a »
hi did u remove the old headliner before fitting the new one or did u just put it over the top?
HD9POLOGTi
Headlining Re-Trim
Post by HD9POLOGTi »
Hi mate was wondering what type of fabric u used wanting to do mine asap dont have have a ducking flue where to start (fabric wise)
ryan_polo
Post by ryan_polo »
Suede always looks good,I know a Trimmer in Leeds who does this kind of thing if anyones interested PM and i can pass on the details.
This is his T4 all done himself looks crazy!
Feeblington
Drives: 6n2 1.4 se
Post by Feeblington »
Well after following your guide. And succesfully removed and replaced headliner. Now my sunroof only closes halfway then opens itself again.....i have to cut ignition halfway then redo it to shut it.....any ideas!? Haha
