6R - Multifunction Steering Wheel Retrofit
Post Instructions on DIY modifications here - use all information with caution!
SergiuMitu
Drives: 6R 1.6 TDI (CAYA) 55kw
Re: 6R - Multifunction Steering Wheel Retrofit
Post by SergiuMitu »
Thank you for suck a great tutorial!!!!
Will all buttons work? (especially from the right side)
I'm having a OEM MFSW with buttons only on the left, i'm planning to add the right buttons to it.
Drives: Polo 6R 1.2 TDI
On the right side, the OK/up/down buttons should work and depending on your head unit, the voice command button should also work.
skoda_indian
Drives: Rapid PQ25
Post by skoda_indian »
Jay-Jay wrote: Tue Aug 22, 2017 11:30 am I've been able to install the two extra wires pretty easily with few tricks:
- I took the LIN bus from driver's door connector (T28a, pin16), which is more more easy to reach, instead of connector T73b, pin 17.
- I used fast electric connectors instead of soldering.
Can I please request you to share pictures of the Driver's door connector and where exactly to locate it?
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Here are two pictures found on this forum:
skoda_indian
Drives: Rapid PQ25
Jay-Jay wrote: Thu Oct 15, 2020 11:12 am Here are two pictures found on this forum:
This is very helpful, thank you!
