Was wondering which rear wipers fit the mk5?! I'm thinking something a bit more smooth and flowing looking like a rear aero wiper off a lupo/newer polo. Will they fit?!
Cheers,
Ben
Rear wiper options.
I think the Lupo came with the same wiper as the Mk5.
There's the 9N aero wiper, which needs to be cut down to fit:
Also, the Mk5 Golf aero wiper, which also needs to be cut down to fit, and the Mk5 Polo estate wiper, which is similar to the ones fitted on the fabia VRS:
Or you could do away with the wiper all together.
haha
Removed all together does look good, but i didn't use the rear wiper for a while to see if i could put up with not having it and it just got migning so quick, so just after i nicer looking wiper.... mates got a fabia vrs so might see if it will fit. Is it a straight swap or need cut down? and by cut down do you just mean the blade?!
cheers,
ben
cheers,
ben
