Ey up boys n gals. I've tredged the interwebs to try and resolve the issues on my polo which i bought on Monday 5th Dec 2016
Speedo doesnt work, on the original one rev, petrol and temp gauges all work fine.
bought another from a breakers yard, same issue, reverted back to the original one and same thing. Thinking speed sensor but i dont know where it is. Can someone please tell me where it is and what it looks like as i have no haynes for the car yet.
Drivers door will NOT open/lock from the outside, will lock from the inside, any ideas?
Boot lock will NOT lock at all, lock does not turn with the key in or is this something to with the drivers door mechanism ??
Ticking noise from the hazard light button, after indicating left or right, it continues to tick for at least 2mins, replaced the hazard light switch and same thing.?? bad earth maybe??
2001 Polo 6n2 speedo issue & other bits :p
- Drives: 2001 1.0E Polo 6n2
Re: 2001 Polo 6n2 speedo issue & other bits :p
Speed Sensor is on the back of the gearbox
Drivers door is a broken paddle. Repair kit on eBay or from the dealer
Boot lock has probably seized up. That's very common as the handle is made from cast aluminium
You might be able to spray some penetrating spray on it and in the lock to try and free the mechanism
Hazard light could be a faulty indicator switch on the steering column or a dodgy bulb
Hi sorry to bring up an old topic but I’m having the same speed sensor issue on my 1.4 TDi, spoke to main dealer about getting replacement but they said there are no sensors on the gearbox?
I haven’t had chance to get under there and see where it is exactly and check for a part number? Does anyone know if this is the right location for this engine? Thanks
