Amp wire help
- Jay_6n2
- Drives: Polo Sel 1.6TDI
Amp wire help
Trying to run the amp power cable through the bulkhead, have gone through this grommit as shown on someones pic i found
fed loads of wire through, but i cant find it on inside, pulled the carpet forward etc, sound deadning,
where should the cable come out???
Jay
Jay
Re: Amp wire help
Comes out up behind the glove box - it can be difficult to get your hands up there and grab it. Just put your hand up behind and you'll find the big wiring loom that comes through that grommet. You should then be able to find the power cable from there
- Jay_6n2
Re: Amp wire help
lol i tried that and cut my hand on something, might be easier when its light out, im so impatient tho!
ill try again in morning then mate, cheers, i was more worried that it didnt even come out in the car
Re: Amp wire help
lol i did that too. Try doing it on a GTI - youve got about as much space as a the gap between closed doors!
Re: Amp wire help
I took my glovebox out, made it uber easy. Especially as I needed to feed a USB wire into glovebox, plus made easy work of feeding cabling away from HU as I fitted it in. Makes it more difficult if you have an airbag there tho!
- Jay_6n2
Re: Amp wire help
done it one swollen cut finger later
Re: Amp wire help
no pain no gain haha
- Jay_6n2
Re: Amp wire help
lol well it sounds good but can hardly drive with a finger thats double size lol
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
Re: Amp wire help
Looks like I wasn't the only person fitting ICE over the festive period
Glad you got it sorted!
- Jay_6n2
Re: Amp wire help
Josh_PoloGTi wrote:Looks like I wasn't the only person fitting ICE over the festive period
lol yeh my neighbours must have thought i was mad, freezing cold in dark fitting wires
Re: Amp wire help
may be an old post but im having trouble,
where abouts in glove box will it be? left up middle down ?
i cnt find it anywhere? and i feeded the hole cable through.
i have a/c so i think thats the problem cause there is a huge box in there.
cheers
cheers
Re: Amp wire help
Its up the back behind the AC unit - absolute pain if you have AC. I had a very sore bleeding hand afterwards
Re: Amp wire help
which side of the air con unit mate? which side did you go from etc?
surely as i put the hole cable through it would come out somewhere?
cheers
cheers
Re: Amp wire help
It comes out behind the insulation. Its up on the right hand side of the AC unit. You have to pull the carpet and stuff down behind it.
Re: Amp wire help
ok i can see the installation from the left hand side looking up,
which side is it from the insulation?
and did u go up from the left or the right side?
