I was wondering if I were to amp my front speakers, where would I put the amp?
Also, as for wiring up the speakers to the head unit and amp, how would I go about doing this?
Would I need some thing like this?..
http://caraudiosecurity.com/shop/produc ... /9631.html - regarding the low and high level adjustment.. what is this?
Thanks.
6N2 Amp location for front speakers?
Re: 6N2 Amp location for front speakers?
Hay,
The amp depending on what you get can be mounted in a whole host of places as long as it has sufficiant cooling and can be mounted as to the manufactureing guidlines etc for example some amps have cooling fins that need to be poiniting in the correct orentation to achive correct cooling of the amp.
The wireing of the speakers: You will need an RCA Lead from the head unit to the amp, along with power and earth cable. Then run speaker cables from the amp to the speakers or crossovers depending on what you are getting.
And from the below link i take it that you wish to use your standard head unit?
Alex
Alex
