Just wanted to know what its like converting dual mass to single mass flywheels..
i heard theyre a bit crappy on gear change?
dual mass to single mass?
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Re: dual mass to single mass?
Changing from dmf to smf shouldn't affect the gear change, should rev a little quicker with the smf as it'll be lighter. G60 flywheel vr6 clutch is a good, well known set up to use with the 1.8ts
