Sorry if these questions have already been asked but I have a 2000 6n2 gti that I am wanting to put jenvey throttle bodies on, I have high lift cams, lightened and balanced flywheel and crankshaft, bigger injectors (which I cannot remember what the ITB’s came with but they are Bosch type plug so imagine they are Bosch injectors
Also another thing I have fully rebuilt the engine but it won’t start up, just cranks fires up for a split second pops a little out the manifold (all I have in the way of an exhaust system at the moment) then dies out, the Rev counter moves so I’m getting a reading from the crank sensor, I believe I’ve timed it up correctly with the correct timing tools, I also found out I have no communication to the ecu when borrowing someones vagcoms? Just wondering is someone can shed some light and point me in the right direction
Many thanks
