Hi
No AC in my 1.2 2003 9n. the condensor fan won't activate when I switch the ac on...
The indicator light comes on, and the heater blower and temperature (hot/cold) adjustment works fine inside the car - just no chilled air.
.... both radiator and condenser fans (Large and smaller one) work when I bridge the pins on the x3 pin fan switch plug that screws into the radiator.
I also managed to spark up the large fan by bridging the 2 large pins on the connector to the control module unit....
Any advice ? - if its low on refrigerant will that stop the condensor fan operating ?????
Matt
AC condenser fan question
- Drives: Mk4
- 937carrera
- Drives: 2000 Polo GTi
Re: AC condenser fan question
Simple answer- yes
- Drives: Mk4
Perfect
Thank you
Best from Brighton...
Matt
Thank you
Matt
- Drives: Mk4
Matt
Matt
