Electrical ignition wiring - 9n3
Posted: Sun May 17, 2020 10:00 am
Hi all.
First time here and I've not had any luck finding the wiring diagram for the ignition.
I'm trying to fit an aftermarket alarm kit (I have a 2009 9n3) that also has remote start.
I've got the immobiliser loop so the car will start and not cut out but I don't have access to a multi meter until next weekend so I'm trying to figure out which two wires are the start signal wires.
It's a decent kit with it's own anti hijack built in that will stall the engine if the door is opened, brake is pressed or handbrake released before the alarm is disabled.
Anyone able to help with this? I don't want to just go twisting wires with the key in just to see which 2 work as that's probably not a good idea!
Please help a man so I have something to do on my couple of days off before I'm back to work
