TT brake upgrade
Joz
TT brake upgrade
Post by Joz »
Hi again fellow dubbers,
I know this topic has been brought up before, but the search button just didn't co-operate today :P
I need to know all the parts I need to upgrade my brakes. I REALLY appreciate it if someone could link me to the parts ^^ :D
dood9n3
Re: TT brake upgrade
Post by dood9n3 »
Caliper and carrier
disks
Bogwoppit
Post by Bogwoppit »
Joz
Post by Joz »
Thanks so much!
Is it not normal to upgrade the back ones as well? :P
buzzmotorsport
Post by buzzmotorsport »
You can upgrade the rear but for normal veryday use it is overkill, my brakes with just the fronts are awesome :)
matthal87
Post by matthal87 »
Joz
Post by Joz »
Thanks guys, looking forward to awesome stopping power :P
Joz
Post by Joz »
quick Q, if someone could answer quickly that would be great!
Will the 312mm disk fit under my 16" gti wheel? :?:
Dom_
Post by Dom_ »
Yes they will, just :wink:
Joz
Post by Joz »
Thanks!
Put my order down^^
Turbomier
Post by Turbomier »
yes they will fit.
about the rear brakes, not nessasery to do them.
pointless will be a better word :wink:
you can upgrade the back if you put a 320mm bbk on it with 4 pot calipers or higher, just for keeping the f/r breakbalance a bit in order.
otherwise it will be just fine to keep the back standard, if you want to improve it, keep youre money and put better discs and brakepads on the back.
more as efficient enough :wink:
Joz
Post by Joz »
Oki, thanks for the tip!
They just look so ridiculously small compared to the new front ones xD
Turbomier
Post by Turbomier »
think of it this way, it is lighter also :P :mrgreen:
