Hi Guys,
I've searched a lot on the website before posting this and just want someone to confirm I have all the right info before I go ahead and order everything, please!
My Dash: https://i.imgur.com/CluTI3k.jpg
- Single DIN: https://www.halfords.com/technology/car ... car-stereo
(This is the back: https://images-na.ssl-images-amazon.com ... L1500_.jpg)
- Installation kit: https://www.ebay.co.uk/itm/270799345089?ul_noapp=true
- Removal keys: https://www.amazon.co.uk/Autoleads-P.../dp/B004Z7IW3Q
- Do I need a fuse tap for the radio to work? (https://www.ebay.co.uk/itm/ADD-A-CIRCUI ... 3a9789c72d)
Is this everything I need and are they all compatible?
Thanks in advance!
European Polo 2007 Radio Upgrade
Re: European Polo 2007 Radio Upgrade
f**k me, get a cheaper fuse tap ya nutter.
£8? You kidding me on? plastic, solder and no fuse? I paid £4 for 3 iirc.
Yes, you'll need one for an ignition live. Easy to do, I used the wiper port and run under the dash.
Removal keys can be got on ebay for £1.99 I think
"Single or Double Din Car Stereo Fascia Fitting Kit For VW GOLF V MK5 2003-2009" Not sure this is the right one. Compatibility settings on eBay would suggest they are. the canbus thing is fine
The radio is fine, you can get a double if you wish... USB on these is s**t for charging, just fyi.
