where does the temp gauge needle usually sit??????
william
temp gauge????
- Tim_GTi
- Post Whore
Re: temp gauge????
Once the engine is warm it should sit at 90
Re: temp gauge????
On The mk3 though it can sit just below or just above.
Re: temp gauge????
when i picked the car up on friday it was sitting at 80...........
yesterda when the heater was only blowing cold air it sat usually in between 100-110:(...........
now after bleeding the heater matrix and getting hot air again it now sits back between 80-90!!!!!
but..........the coolant level was slightly low this morning but nothing major,and there is signs of emulsification on the oil cap!!!!
william
william
Re: temp gauge????
Top the coolant up and see how it goes.
You have a leaking thermostat housing - have a look around the casing.
