I am trying to install some LED strobe lights behind my front grille.
I have removed the front VW badge, and there is a clip on the bottom part of the grille which is easy to unclip (at the botton of the VW badge).
BUT I can't remove the top of it...
How do uI remove it?
And also, is there a place to feed the wires through from the bonnet to the centre console inside the care.
Thanks.
!!!! How to remove front grille? HELP!!!!!!!!
Re: !!!! How to remove front grille? HELP!!!!!!!!
4 clips at the top. Pop the bonnet up and you will see them.
