This says that you are doing something wrong. Did you follow my suggestions? Please post the full vcds scan. Also kindly show us your wiring connections.
Thanks.
I highly suspect your blue T12 connector of quadlock. The T12/12 black wire is partially out of its place, inspect it. And also provide clean +30 power to RVC for your tests.Mocro wrote: ↑Sun Jan 10, 2021 9:51 pm I had a fuse tap but also with fuse tap it doenst work, i did this totday because with fuse tap the fuse wont get fully in the fusebox.
The reason why it sais it have 11.1 V is because the car wasn’t started. When i start the car it wil go to 12v.
Iknow that the way i do is risky but it was for the test.
I think it it something with the rvc cable to the MIB2. Is it possible that the pins in the MIB2 are broken inside or something?
The weirdest thing is that everything worked fine but after a few km it doesnt work
That is my microphone I replace other t12 connector of the quadlock now everything is on its place. I inspect everything, the fuse is +30.patil wrote: ↑Mon Jan 11, 2021 12:06 am
I hope your boot is closed when you are making tests.
I doubt the MIB2 pins are broken, they are strong and hard. Anyway inspect.
Do complete thorough examination of your wiring.
Kindly post the requested full VCDS auto scan for clarity and to avoid confusions.
Thanks.
Dinsdag,12,Januari,2021,17:51:43:00009
VCDS -- VAG/VAS Emulator onder Windows Loopt op Windows 10 x64
VCDS Versie: PRI 19.6.1.0
Data versie: 20190815 DS308.0
www.Ross-Tech.com
Chassisnummer: - Kenteken:
KM-stand: - Reparatieorder:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 14 15 17 19 44 5F 69
Chassisnummer: WVWZZZ6RZGY099627 KM-stand: 127542km
01-Motor -- Status: OK 0000
03-ABS Remmen -- Status: OK 0000
08-Airco/Verwarming -- Status: OK 0000
10-Park/Stuurassist -- Status: OK 0000
14-Wieldemping -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
44-Stuur Hulp -- Status: OK 0000
5F-Info Electr. -- Status: Functioneert niet 0010
69-Aanhanger -- Status: OK 0000
Adres 01: Motor (J623-CUTA) Labels: Geen
Onderdeelnr. SW: 04B 997 027 J HW: 04B 907 445
Component: R3 1.4l TDI H08 9439
Revisie: 21006001
Codering: 01114032423401080000
Dealer #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TDI03004B997027J 004003
ROD: EV_ECM14TDI03004B997027G.rod
VCID: 326BAFCF652F68DF5F-8066
Geen foutcodes gevonden.
Gereedheid: N/A
Adres 03: ABS Remmen (J104) Labels:. 6R0-907-37x-ESP90.clb
Onderdeelnr. SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serienummer: 08505322150909
Codering: 21DD48858B2C33C9091A306B00588412D1CC900C0007C9098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 377D9EDB8E4D8DF768-8062
Adres 08: Airco/Verwarming (J255) Labels:| 6C0-907-044.clb
Onderdeelnr. SW: 6C0 907 044 B HW: 6C0 907 044 B
Component: Climatronic H02 0202
Serienummer: 1509021A-0931
Codering: 201000001011200201
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: 23455A8B2AD5F157A4-8076
Adres 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Onderdeelnr. SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0094
Serienummer: 001588012482
Codering: 0012085042530AFB4F844000402F07D800005B0253010000000000000000
Dealer #: WSC 12345 123 12345
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 3169A0C3602953C726-8064
Sensor voor regen- en lichtherkenning:
Subsysteem 1 - Onderdeelnr. SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serienummer: S4Y15M09D11H01M15S51
Codering: 9038DD
Portierregelapparaat bestuurderszijde:
Subsysteem 2 - Onderdeelnr. SW: 6R0 959 801 CE HW: 6R0 959 801 CE Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 9612
Serienummer: KU0KU016091552594078
Codering: 0400A1
Portierregelapparaat bijrijderszijde:
Subsysteem 3 - Onderdeelnr. SW: 6R0 959 802 CJ HW: 6R0 959 802 CJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 9612
Serienummer: KU0KU008091552510560
Codering: 1400A1
Regelapparaat voor schuifdak:
Subsysteem 4 - Onderdeelnr. SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.403 H03 0004
Serienummer: 0000FST000HNTQN00000
Codering: 181001
Sensor luchtvochtigheid: binnen:
Portierregelapparaat achter: bestuurderszijde:
Subsysteem 6 - Onderdeelnr. SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serienummer: KU0KU010091552533482
Codering: 0400A0
Portierregelapparaat achter: bijrijderszijde:
Subsysteem 7 - Onderdeelnr. SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8611
Serienummer: KU0KU014091552571924
Codering: 1400A0
Adres 10: Park/Stuurassist (J791) Labels:| 5Q0-919-294.clb
Onderdeelnr. SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revisie: -------- Serienummer: 39391525300172
Codering: 0031351101
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 3D718CF3AC71A7A7B2-8068
Adres 14: Wieldemping (J250) Labels: 6C0-907-359.clb
Onderdeelnr. SW: 6C0 907 359 HW: 6C0 907 359
Component: DAEMPFUNGS-SG H04 0007
Serienummer: 10091502000084
Codering: 80
ASAM Dataset: EV_SwitcDampeContiTemic 001004
ROD: EV_SwitcDampeContiTemic.rod
VCID: 6ADB77AF8D7FE01F27-803E
Adres 15: Airbags (J234) Labels:| 6C0-959-655.clb
Onderdeelnr. SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag00P 001 0360
Revisie: -------- Serienummer: 003RJ0055RSS
Codering: 88CCC000000000005C0000CA000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 366393DF894774FF73-8062
Ongevalsensor voor zij-airbag: bestuurderszijde:
Subsysteem 1 - Onderdeelnr. SW: ----------- HW: 410 821 209 15
Component: SideSensor_Df 151 0800
Serienummer: 3575H00A11D1690141B9
Codering: 2D2D2D
Ongevalsensor voor zij-airbag: bijrijderszijde:
Subsysteem 2 - Onderdeelnr. SW: ----------- HW: 410 821 209 15
Component: SideSensor_Pf 151 0800
Serienummer: 3585H00B91D5010233AA
Codering: 2D2D2D
Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
Subsysteem 3 - Onderdeelnr. SW: ----------- HW: 442 150 109 15
Component: SideSensor_Dr 1CA 0148
Serienummer: 3517A00B91C4E1E2E35U
Codering: 2D2D2D
Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
Subsysteem 4 - Onderdeelnr. SW: ----------- HW: 442 152 808 15
Component: SideSensor_Pr 1CA 0148
Serienummer: 3527A00B91C3DED4345X
Codering: 2D2D2D
Adres 17: Instrumenten (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Onderdeelnr. SW: 6C0 920 741 C HW: 6C0 920 741 C
Component: KOMBI 201 1420
Codering: 07250900318000080D087A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
Adres 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Onderdeelnr. SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H08 0094
Revisie: -------- Serienummer: 001588012482
Codering: 030100344F0A590071000000800000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2643439F59E7047FC3-8072
Regelapparaat voor multifunctiestuurwiel:
Subsysteem 1 - Onderdeelnr. SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serienummer: 2531507341700601AD1B
Codering: 280000
Regelapparaat voor accubewaking:
Subsysteem 2 - Onderdeelnr. SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serienummer: 62262M18192821707121
Adres 44: Stuur Hulp (J792) Labels:| 6Rx-909-144-V2.clb
Onderdeelnr. SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serienummer: PF9R0101
Codering: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6DD17CB3BC91F72742-8038
Adres 5F: Info Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Onderdeelnr. SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER H24 0252
Serienummer: VWZAZ2R0492223
Codering: 02620001BE00000051110001000808031F0300D401200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 6ED37BBFB1970C3F7B-803A
Weergave- en bedieningseenheid 1 informatie-elektronica:
Subsysteem 1 - Onderdeelnr. SW: 6C0 919 603 A HW: 6C0 919 603 A
Component: ABTm_Std2_Nav H53 1031
Serienummer: VWZ8Z9SKX02DCA
Sticker met gegevens:
Subsysteem 2 - Onderdeelnr. SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Serienummer: --------------------
2 foutcodes gevonden:
1556 - Regelapparaat defect
B2000 87 [009] - Geen boodschap
Bevestigd - Getest sinds Wissen Geheugen
Freeze frame:
Fout Status: 00000001
Fout Prioriteit: 6
Fout Frequentie: 1
Reset Teller: 129
KM-stand: 127542 km
Datum: 2021.01.12
Tijd: 17:48:26
Spanning contact 30: 14.6 V
System_Software_Error-SW_Status_Consistency: 04 01 01
System_Software_Error-SW_Status_Device: o
6720 - Achteruitrijcamera
B1102 31 [009] - Geen signaal
Freeze frame:
Fout Prioriteit: 3
Fout Frequentie: 1
Reset Teller: 129
KM-stand: 127542 km
Datum: 2021.01.12
Tijd: 17:47:57
Adres 69: Aanhanger (J345) Labels:| 5Q0-907-383.clb
Onderdeelnr. SW: 6C0 907 383 F HW: 6C0 907 383 B
Component: Anhaenger H21 0203
Revisie: 8D001003 Serienummer: 0375570934
Codering: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 2D51BCB37C11372702-8078
Einde----------------------(Tijd verstreken: 02:46)------------------------
Thank you, How can I connect the the can lines directly?patil wrote: ↑Wed Jan 13, 2021 1:21 pm Ok Mocro, thanks for the autoscan. It would have been better if scan was in English, anyway it's ok.
If wiring is checked and everything is proper, then please check output at T12/6& T12/12 blue connector using multimeter. And also in address 10 adaptations, try setting reverse camera as display for park assist. Also I would suggest to connect can lines directly to MIB2 can wires rather than using converter supplied by the seller.
I've installed similar camera as yours, works well for me on MIB2. But my wiring connection is slightly different. I tapped +30 power from MIB2 power with inline fuse and ground from +31( MIB2 ground) and canlines directly connected as I mentioned above.
Please also do check your boot lock switch wiring for any short circuit.
Hello Macro,Mocro wrote: ↑Wed Jan 13, 2021 10:57 pm
It has 2 wires, do i have to solder it or something else?
I also testes the camera without the canbus converter from the seller and using the OEM cable of the canbus, but also it didn't work.
I think the +30 and the ground is'nt the problem, i always had a camera never was a problem until i changed for a new camera with can lines.
I will check this week the blue connector t12/6 and t12/12.
The usual suspect, that's why I was telling you to test the output of T12/6 &12 to check if camera is working.
