OEM Bi-Xenon Headlights with LED. For VW Polo 6r 2009+
just noticed on e-bay these xenon headlights for sale,if anybody interested.
item number is 110649044794.
- whitegtipolo
Re: OEM Bi-Xenon Headlights with LED. For VW Polo 6r 2009+
Rip off can get em a lot cheaper bud about 600 all in
- Edi30
Yes I think I remember from a previous post that VW sell them for £295 per side plus bulbs.whitegtipolo wrote:Rip off can get em a lot cheaper bud about 600 all in
Hi all,
GTI owner from Australia here.
Where can u guys pick up the OEM Xenons with LEDs for so cheap? 600 GBP?
Cheers,
Jules
Cheers,
Jules
- whitegtipolo
If you spec the bi xenons you get a sensor in the rear suspension and one in the top of the windscreen to sort out the self levelling. These will cause you all sorts of problem retro fitting them. Just get some aftermarket xenons as i have done....job sorted.
- Edi30
You could get away without the self levelling as they come with height adjusters. After Market kits are the best value but if it's OEM Xenons you are after then it is not going to be cheap.Blaade wrote:If you spec the bi xenons you get a sensor in the rear suspension and one in the top of the windscreen to sort out the self levelling. These will cause you all sorts of problem retro fitting them. Just get some aftermarket xenons as i have done....job sorted.
- Tyler Owen
Do you have issues with the wiper motor after fitting Aftermarket HID's on the Polo ? or is it too soon and noone has burnt one out yet
Only Reason i ask was that its very common problem the A3 and Golfs etc
- whitegtipolo
Nah based a lot on the 9n3 tbh so will be ok
found this: http://www.kufatec.de/shop/product_info ... lo-6R.html
Might make installing the OEM Xenons a hell of a lot easier?
Does anyone have the part numbers to do this conversion ?
- Edi30
Welcome to the forum. Sorry can't help with the part number suggest you ring your dealer.20VT wrote:Does anyone have the part numbers to do this conversion ?
Prepare for the shock of the cost of the lensors that control the auto levelling too....
- whitegtipolo
b*******s to auto levelling being to anal Lolz. Fit an after marked hid conversion kit the lamps on polo are really good and you still get a god beam pattern. I have winter pack so headlamp washers are present but not heard of anyone being busted for hid kits tbh.if it comes into mot just fit your bulbs back in for it .
You guys are lucky over there, my Girlfriend's dad got done for having retro-fitted HIDs in his 100 series lancruiser high-beams on the weekend, cop was parked behind a tree and got him at 11pm in the middle of the bush. Quite a few people are getting nabbed over here now, I'm guessing the coppers are getting sck of being blinded while driving down the freeways now:) Now they're stinging people for incorrect usage of fog lamps too....
