Change inside lamps of Polo
Hi ppl
I need help to open the supperior interior lamps to change to led's my problem is that i don't see anything to open and i don't want to scratch because the polo is new can anyone help me?
Anyone know a place with photos to open inside case to replace the lamps (central lamps closed to mirror)
Thank you
Thank you
Re: Change inside lamps of Polo
Heres what the workshop manual says (recommends removing the alarm sensors first so have included this): -
Switch off ignition and all electrical consumers and remove ignition key.
Remove trim -1- from roof trim in direction of -arrow-.
Disconnect connector -2-.
Unclip sensors -3-.
Release cable from cable guide -4-.
Remove interior monitoring control unit together with vehicle inclination sender -1- and interior monitoring sensors -3- from interior light.
Carefully lever out lens of interior light with switch-off delay -W15--1- with removal wedge -VAS 3409--arrows- and remove.
Unclip locking lugs -arrows- and remove interior light with switch-off delay -W15--1- from roof trim as far as cable lengths permit.
Release microphone connector -1- and disconnect.
Release connector -2- for interior light with switch-off delay -W15--3-, disconnect and remove front interior light with switch-off delay -W15--3-.
Unclip sensors -3-.
well many thanks i was piced of trying to find this information so i buy the manual 30m ago LOL no problem i think in the future can do me a lot of favours
Thanks for all gonna try thanks again
one other thing can u please tell me what lamps that this thing have what type of lamps to i change to leds please
anyone know the tip of lamps that it take on inside?
There are at least three different types of interior lights depending on equipment version. Some of them use different types of bulbs.
If it's the one pictured above, then they're W5W/501.
ok many thanks
- mashmarriner
Hey I changed my interior lights to green. The ground 3 501. No problem all worked spot on. But wen it came to te rear. I changed one at a time wen I changed the first one everything worked good. But once I put the last one in that's wen it went to pot.
The lights do work wen they are one constant but none work wen I open the door no matter what I do. Even wen I change it back to the way it was can anyone help please
Did you ever sort out your interior lamp not working? How did you get your rear interior lamp out?
SteveP wrote:Heres what the workshop manual says (recommends removing the alarm sensors first so have included this): -
Unclip sensors -3-.
I don't suppose it tels you in the workshop manual how to change the rear interior lights?
Give me a few days and I will post a few pics of when i changed mine. It will show you where the brackets are to get them out...CANDYMAN wrote:Did you ever sort out your interior lamp not working? How did you get your rear interior lamp out?
Nice one Can't wait
- NeilMcConville
Having LEDs inside really does make your car stand out cause not many have white lights inside and IMO they look much better, although the ones I have do not project as much light as the standard bulbs did but i've no concerns about that
