[DIY] Polo 6C BiXenon Fog Lights
Eduard
Drives: 6C
Post by Eduard »
Hello gents, here comes my second retrofit, front fog lights, after going from halogen to xenon.
As you already know, the DRL from the front bumper becomes the Fog Light.
Found this on CS: http://www.carsystems.pl/vw-polo-6c-fog ... d2161.html (unless you want to do your own wiring)
Also found that under T46b connector, slots 3 and 40 are responsible for the Right and Left Fog bulbs ( in that order ), so now we know what goes where.
As for the tiny blue cable, it runs from your T10k/5 (Rotary Light Switch) towards T73c/31 ( front / rear fog light switch ) ( but is most likely not needed, as there is already a wire there for the rear fog lights. Someone could explain that scheme better, if possible, as I am not sure about the blue cable )
https://imgur.com/S7AUzdh - BCM --> Fog Light Bulbs
https://imgur.com/X5Yf2Y3 - Rotary Light Switch ---> BCM
https://imgur.com/kmO2Fwk - BCM slot
** Note that I made this from the back of my head by just looking at the wiring Diagrams, feel free to correct.
Will be back with the more info and pictures once done :)
MethOdMat
Drives: Polo 1.2 TSI dsg7 Lounge 2015
Re: [DIY] Polo 6C BiXenon Fog Lights
Post by MethOdMat »
Hi, if you come back here, does this worked ?
The Fog Light Wiring you bought is ok ?
Last active:13 Feb 2021 12:01
doubtful :P
