Fuse overview VW Polo 6R and 6C
slicendice
Drives: Black GTi 2016 (6c)
Re: Fuse overview VW Polo 6R and 6C
Post by slicendice »
I'm trying to hardwire a dashcam into my g/f's 65 GTi (6C) and not sure about the fuse connections. It's got parking mode so needs Acc and Vcc.
Re the fuses to piggyback onto - from the PDF diagrams above (Polo 6C 2014-2018), I'd gone for Vcc => fuse 5 (driver's door control unit) and for Acc => 23 (washer pump)...are those OK?
I got a couple of tap fuses but when trying to fit them, they just don't seem to fit well around/over the existing fuses (i.e. the blades don't sit nicely due to the tap'd fuses pressing against the existing fuses). For other's who have done this, did you use the standard size fuses to piggyback? Or would it be better to go for the mini fuses? And if so, which ones would be good ones to use? Possibly Acc => fuse 36 (heated front seats), Vcc => fuse 17 (anti-theft alarm sensor)?
I'm sure I read somewhere (though can't remember where!) that it's best to use fuse slots that are rated 10-30A - is that true?
Sorry, that's a lot of questions in one post! :-)
For ACC I'd recommend a fuse between 24 and 37 (75/15 in the most right column in the fuse overview). For VCC you can take any fuse with 30 in the right column, 5 is fine.
slicendice
iichel wrote: Tue Jul 07, 2020 11:27 am For ACC I'd recommend a fuse between 24 and 37 (75/15 in the most right column in the fuse overview). For VCC you can take any fuse with 30 in the right column, 5 is fine.
Brill, just what I needed...thank you!
All now wired in and working.
water ingress into areal, i also had this issue. There is an amplifier inside the antenna.
Damon
Drives: 2010 Polo Moda 64
Post by Damon »
For 6R can someone indicate the locations of ACC fuse, to connect reverse camera to
have a look at this, Damon.
franticspider
Drives: Polo 62 1020 1.2l
Post by franticspider »
I blew a fuse for the screenwash pump because I didn't put any screenwash in my tank and the water froze. First thing I knew about it was when my front wipers didn't work!
It took ages to trace the fuse - eventually checked every single fuse under the steering wheel.
For me it was fuse 2 - the very last fuse I checked! This made sense when I realised I'd blown the washer fuse - really surprised that this stopped the wipers working as it isn't stated anywhere!
thanks to this forum I didn't have to take it to a garage. Sharing this info in the hope of giving something back - VERY HAPPY
cheers buddy, happy to help you out in this way
KDC
Drives: 2017 bluemotion
Post by KDC »
Similar issue today on wifes tsi bluemotion, fuse 23 underdash.... checked all with multimeter, 7.5amp.
definitely more to do with frost,as she hates to use screenwash...dunno why costs me nothing for the blue stuff....but she ignores the 5 litres of concentrate at the door step
Sasha70
Drives: MK5 6C
Post by Sasha70 »
Good day everybody.
My daughter changed her car from 2006 VW Polo to 2014 VW Polo 6c 1,0 BlueMotion, facelift model.
Today I have noticed that relay R1 is missing at engine compartment fuse box, just Bridged with wire.
Could you please help me to find correct relay.
Thank you in advance.
Congoey
Drives: 6r
Post by Congoey »
OllyDale wrote: Thu Jul 04, 2019 8:41 pm Hi all, new to the forum
My wife’s 2015 polo has been having problems with the tailgate lock. I assumed it was the actuator as it became unreliable and then finally gave up the ghost. Have replaced the lock, but completely dead now. I assume there is a fuse, but cannot find it recorded on the overview.
Anyone able to help?
Did you ever fix this? I'm having the same issue. Thanks
algerino77
Drives: Polo 6R 1.2 TSI 105 DSG7 CARAT
Post by algerino77 »
are there any instructions how to open the fuse box cover.
I removed the air duct, Remove the fuse box down.
How do I open it to access the wires? Are there any instructions ,?
pry on small tab and slide it down
Guys can i get a little help.
How do I remove the fuse box connector from fuse box carrier?
giannis20vt
Post by giannis20vt »
Take a look at ciclo's thread. viewtopic.php?t=58703&hilit=ciclo+polo
You could find everything you are searching for.
for example:
https://drive.google.com/file/d/0B2nv91 ... 7CmelyxF9g
giannis20vt wrote: Sat Feb 25, 2023 7:22 am Take a look at ciclo's thread. viewtopic.php?t=58703&hilit=ciclo+polo
for example:
Thank you very much!
