Thankspatil wrote: ↑Sat Jan 23, 2021 3:28 pmThe usual suspect, that's why I was telling you to test the output of T12/6 &12 to check if camera is working.
Anyway, thanks for informing us.
To find the +30 signal in fuse box, visually inspect the fuse box for presence of terminal inside any of empty fuse slots. If you find any then use multimeter or 12v tester to find out the type of signal present.
Thanks.
Help fitting Reverse Camera with RCD330 - Canbus
- Drives: Polo 6C 1.4TDI 105HP
Re: Help fitting Reverse Camera with RCD330 - Canbus
Iknow that this is not ok, if my OEM flip camera is deliverd i will do it the correct wise. But know nothing is working and my OPS also i opened a new topic.
Maybe you guys know this problem, thanks patil i saw your reaction i will try it.
Yeah I managed to feed it through.
I just need to make small hole to feed the cable through the rubber at the moment I’ve just got it hanging out.
So what’s your current issue so I understand
Do you see a video image then it goes off? Or not at all?
Mine did that it could come on once then go off, didn’t show lines but camera showed. Had to restart car to get camera to work again for a few seconds.
For me it was because I hadn’t connected the camera can cables for the existing can once done it wokeee fine.
No i see only black screen and then it turn off withe message ''Parkpilot is not available'', but i remove it. I will install OEM flip camera in it, I still waiting voor the harness.Damon wrote: ↑Sat Jan 30, 2021 9:28 amYeah I managed to feed it through.
I install OEM golf 7 camera logo on my polo without any issues thanks everybody for the previous problem
- 169E80E1-3EF6-43D6-BBFF-00166BE2E5AB.jpeg (2.6 MiB) Viewed 704 times
Yes i soldering it on the quadlock +30.
Thanks i will do it.
