6R IMPOSSIBLE IMMO PROBLEM
- Drives: 2012 6R 1.2 TDI Bluemotion
Re: 6R IMPOSSIBLE IMMO PROBLEM
Some good news happened.. We swapped the amarok cluster with Abrites. But after the swap ABS module long coding turned into a bunch of zeros. We tried some codes from a couple of forum sites. Unfortunately none of them worked. Can anyone now the solution ? 1.2 TDI CR Bluemotion with ESP and VIN number is WVWZZZ6RZCY207134.
- Drives: VW UP/Passat B6
You did not save original ABS coding? Or made a full auto scan anywhere before in the past?
I see you used ODIS in the past, maybe you have stored a full log of it somewhere? There you can find your original ABS coding also.
Goodluck,
H2Deetoo
Goodluck,
H2Deetoo
Thank you but again unfortunately I do not have a full log. I used odis at the workshop so the computer was not mine. Today we take a log from another polo. We will try that but im not so sure if it will work.
