Polo 6r bi - xenon retrofit problem
Hello, I have a 2013 model polo 6r 1.6 tdi
-I did the bcm upgrade (7e0937090) 6r0937086m to 7e0937090
I also made the 10 pin to 14 pin harness
I have a problem like this, the vehicle does not make high beam in 0 position and it is in parking position
also cornering lights do not work (no factory fog lights)
What should I do? Can you help me?
Re: Polo 6r bi - xenon retrofit problem
I think it would be nice to see some more information.
Perhaps you can start with a VCDS autoscan or another diagnostic report to see any errors and codings of all modules involved.
OK, I will share that information with you when I got it in the car garage, but there is no error in 09 central electricity, I did the coding as described by ciclo only (03433 - terminal 30 for backup lights and adaptive lights) error is available now
it would be very useful if you describe exactly what you did for the bcm replacement (wiring, coding) and bi-xenon headlights (wiring, coding)
Sunday,28,February,2021,13:53:51:24024
VCDS Version: 20.4.2.0
Data version: 20200807 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDYXXXXXX License Plate: 53AR766
Mileage: 74700km-46416mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZDY199275 Mileage: 74700km-46416miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MA HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9978
Revision: --H33--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023MA 003011
ROD: EV_ECM16TDI02103L906023LK_SK25.rod
VCID: 71F7908FDCE8FE1218-8024
Readiness: 0 0 0 0 1
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412C00C984161470825600420905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F896CF12496026CE8-805A
Component: LENKW.SENSOR H06 0070
Serial number: 26011304650944
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF88EA6E0ABAC7760-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39BF0077F4C00E8A58-806C
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 036161133
Coding: 3CB02FBF48A10000093808C07CAB0FD0FAC0675F600D1040200000030000
Shop #: WSC 29330 001 104857
VCID: 68EEA2E4B0D528DDD0-803C
Component: RLHS 200618 0 50 0107
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU020111200011827
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU023111200014572
Coding: 18BC30
Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO1956069A
Coding: 081001
Subsystem 5 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0449392
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU015011300012686
Coding: 18BC32
Subsystem 7 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU016011300011561
Coding: 18BC32
3 Faults Found:
03433 - Terminal 30 for Backup Lights and Adaptive Lights
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 74702 km
Time Indication: 0
Date: 2015.07.22
Time: 13:50:13
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 102
Mileage: 74702 km
Time Indication: 0
Date: 2015.07.22
Time: 13:50:15
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 74702 km
Time Indication: 0
Date: 2015.07.22
Time: 13:50:13
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10Airbag00E H10 0020
Revision: -------- Serial number: 003GW00GLYVO
Coding: 003045
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CFE0073CB0EEFAD8-801C
Part No SW: 6R0 920 861 K HW: 6R0 920 861 K
Component: KOMBI H03 0306
Serial number: 00000014669802
Coding: 140A01
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3DBB086BECEC36AE78-8068
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H03 0015
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25_VW25.rod
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Shop #: WSC 00788
VCID: 30B6124C442D785510-8064
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2R7388032
Coding: 16000440040001
Shop #: WSC 00081 790 00179
VCID: 46C0FE0E0883FCEFA0-8012
End-------------------------(Elapsed Time: 02:42)--------------------------
byte 11 -> C1
byte 16 -> 5A
you should probably fit the wire from SB57 (or any other permanent positive) to T73b/11 to make the LED DRL work
byte 16 -> 5A
the changes I've made
- I connected instrument cluster bcm white connector 54-57 ic (28-29), the existing one is 28-29
- I pulled out the line from the bcm a63 + b68 permanent positive fuse box
- I drew a new line from t73b / 7 to the backplate lamp, isolating the existing line and
- finally I pulled headlight sockets for 10 to 14 bcm a5 / bcm b3 / b5 / b6 / b9 / b10 / new lines
So change byte 11
Is there a wire for t73b/11? Is there a wire to t14/14?
Then that's the problem
