VCDS Help?
EdenBanim
Drives: 2011 Polo 6R TSI
VCDS Help?
Post by EdenBanim »
Hi!
I've just installed aftermarket headlights on my 2011 6R which uses LEDs as parking light and on the indicator lights and as expected - I got a bulb error on the cluster.
I replaced most of the bulbs to led and just used VCDS to disable the bulb diagnosis via the "Long coder helper" but there is no option to disable the parking light\ front indicators via the helper..
I searched this forum and other sources but didn't find any related information.
Maybe someone here knows how to do it?
The headlights: Image
Thanks!
Re: VCDS Help?
There is no option to disable the parking light or indicator diagnostics, unfortunately.
EdenBanim
Re: VCDS Help?
Post by EdenBanim »
iichel wrote: Sun Feb 28, 2021 10:26 am There is no option to disable the parking light or indicator diagnostics, unfortunately.
So I'm stuck with the error light?
Is there a way to disable it completely? or any other solution?
Re: VCDS Help?
Dont those headlights come with a resistor?
Resistor, or splice in a halogen bulb and hide it away.
Re: VCDS Help?
EdenBanim wrote: Sun Feb 28, 2021 3:16 pm
revert to halogen bulbs for parking light at the rear and indicator all around
EdenBanim
Re: VCDS Help?
Post by EdenBanim »
The error light turn on only when I installed the headlights, they were plug-and-play and they don't have any resistor on them (at least on the outside).
Low and high beam are halogen.
Steve11115
Drives: Mk 5 1.4 tdi
Re: VCDS Help?
Post by Steve11115 »
Sorry to jump on your post, but having issues with a few codes could anyone help?
00608 - load sensor g119
01555 - motors for central locking save
00013 not sure
EdenBanim
Re: VCDS Help?
Post by EdenBanim »
Maybe someone knows which pins on the headlight socket are for the parking light and indicators so I can put resistors on them?
