I am trying to change my fog lights to LEDs but cannot seem to find anything that will fit the current connector, Any help would be appreciated. I have attached a couple pictures below of the connectors i have.
The below is what the bulb connector looks like
Here is a set of LED plug and plays i brought but dont fit, All the ones i find look like this.
Change Fog Lights to LEDs
- Platinum Member
Re: Change Fog Lights to LEDs
Are you sure that the LED in last pic will fit?
H11 connector but will fit h8 also. - this will fit the bulb on last pic.
Hi Amer,
Thats the question i am asking, I am trying to identify the original Connector on the Car and Bulb so i can purchease the correct type.
How would that adapter fit into my car?
- Platinum Member
What does it say on the bulb on first two pictures?
What year is your car? If you are uncertain can you post an image of tge whole bulb showing
- Platinum Member
You need w21w led(canbus) to plug into factory bulb holder if you dont want to make your own adaptor for h11/h8
