ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Drives: 6R Rline/G7.5/Touareg Rline'19/T-Cr'20
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
danikd wrote: Fri May 07, 2021 9:23 pm Yes than select dataset witj TJA
https://www.golfmk7.com/forums/index.ph ... -r.360141/
Proof, not mine, Iam always late :) Very busy now ...
https://www.youtube.com/watch?v=J1fZNhxmVVA
Ok, got it, thanks for the info.👌
Maybe I will after testing everything under normal conditions.
danikd
Drives: Citigo
Post by danikd »
Great, let us know, as always...
Golf 7.5 A5 camera installation.
- The camera calibration remains to be done. Basic setting.
660 - No Basic Setting
B2010 00 [009] - -
[Initial_calibration_missing]
- The RLHS is new (as you already know), it works correctly after the coding has been transferred.
- I decided to install the original factory anti-dazzle mirror, with plastic edges. If I had installed the HBA mirror without plastic edges, it would have lost the non-dimming function when reversing, due to the wiring configuration when installing the A5 camera.
HBA mirror performs this function via CAN and original mirror via reverse signal (blue/black wire).
- The windshield was installed in a VW dealer (assuming a high level of stress) ... :arrow: viewtopic.php?p=583398#p583398
Golf 7.5 Anti-theft alarm system + New RLHS. Coding.
BCM adaptation SECURITY ACCESS--> 31347
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,not active ,8	... Active
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8 ... Active
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8 ... driver door contact thatcham
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,not installed ,8 ... sounder installed
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,not_active ,8 ... active
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8 ... active
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,No ,8 ...yes
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,No ,8 ...yes
Setting parameters for Golf mk7.5 (not Variant), """NO Parking heater, NO trailer hitch, NO Kessy"""
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66
Lock & unlock horn confirmation:
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10 ... not active (with alarm)
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10 ... normal or short (with alarm only)
Previously coded.
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,10 ... active (open)
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10 ... active (close)
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10 ... active
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10 ... active (Menu infotainment system)
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 72007150025702
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW37.rod
VCID: 015F7878518EE16380D-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S5Y20M05D14H05M53S24
Coding: 06A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY191251XZQ
Alarm horn:
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Component: Sirene, DWA 005 0313
Serial number: 00002854456462182207
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
A new option appears in the menu for the door opening and closing settings, allowing you to deactivate the monitoring of the interior sensors in the event that someone or something is inside the vehicle.
In the event that the interior sensors need to be deactivated, they must be deactivated before removing the key from the ignition switch.
It works like the old button located on the B-pillar, it is activated automatically for the next time.
Added the following adaptation to the previous adaptations, it allows the deactivation of the interior monitoring by 'double click' on the closing button of the remote control.
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8 ...active
It works perfectly. :)
The usual faults before camera calibration.
2 Faults Found:
13705999 - Databus
          U1123 00 [137] - Received Error Message
          [Kamera_FDD_Funktionsstatus_Fehler received error status]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 35726 km
                    Date: 2021.05.10
                    Time: 09:25:57
13706000 - Databus
          [Kamera_FDD_Eigenblend_Guete received error status]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 134
                    Mileage: 35726 km
                    Date: 2021.05.10
                    Time: 09:25:57
They go out once the camera is calibrated.
Golf 7.5 Front Camera Calibration for Driver Assistance Systems. 8IU LED Headlight adjustment.
Dynamic Light Assist
Lane Assist
Dynamic Road Sign Display
VCDS Autoscan
Tuesday,11,May,2021,13:54:39:32438
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: A5 CAMERA OK! Dynamic Light Assist, Lane Assist, Sign Assist.
Mileage: 35810km-22251mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 A5 A9
          D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 35810km-22251miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC923F8D-807C
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DBA5F-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011105004000101022
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D8734C87D161503545-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 06A8DD
   Alarm horn:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318277
   Coding: 0271167841
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF8838C16ED1E350D-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00678119FFC728949C810560400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C344BEBB-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA923D8D-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07AD2A806E8C000801887A0F1401000000000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB330A1-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012020001767
   Coding: 030100047F085700DB0002FE080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B92DBC6A24F8EB7F3-8024
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002063230049307
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
   VCID: 47CBA6603F2A1F530E9-8012
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64583A45-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150320D000048000001000
   Shop #: WSC 00020 999 12345
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102B073-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 931F0000
   Shop #: WSC 12345 102 209715
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F3821-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 01081930001280
   Coding: 00000005090016420120DF47020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD37E9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000005111000100880A001F0500F401200000CF
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFB497-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CB5BB-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H10 0610
   Serial number: 28011912K23389
   Coding: 000307000000040100221354C146A80094000E33004000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9BD7C1A04286BCF3-8014
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6A8D3FD44CF8023B317-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392FD09879DE79A388D-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:39, VBatt start/end: 14.4V/14.3V)-----------
Everything seems to work fine, but I have yet to test the DLA. Tomorrow I post the codings I did on my wife's golf.
dcgumis
Post by dcgumis »
Very good :D If you code it, show it how DLA works :D
I'd like to do it, but now I don't have the proper tools to show how DLA works. Maybe in the future,
if you followed this thread carefully, I still have a +30 signal to fill ... :lol:
Over time I will comment on my impressions regarding DLA.
Golf 7.5 A5 Camera. Coding - Adaptation. DLA Test OK!
First impressions:
With the Basic Light Assist and with the Dynamic Cornering Lights the road lighting with the 8IU LED headlights was already very good, the headlights danced according to the movement of the steering wheel.
By adding the DLA and some predictive functions a higher level is achieved, the independent dance of the lights of each LED headlight depending on the traffic conditions and the driver's requirements makes driving at night a real pleasure.
The lights move independently on each LED headlamp, like a chameleon's eyes :), left, right, up, down, ... a very pleasant choreography that exquisitely illuminates the road, right when and where needed without having to do anything.
A5 Camera. Coding - Adaptation. DLA, LA, SA, 'the work I did at my wife's Golf'
Activation:
Dynamic Light Assist, 'Adaptive' Lane Assist, and Sign Assist, ... with 8IU LED headlights.
CODING
03... Coding
Electromechanical parking brake: emergency braking
Byte29 Bit5... enable.
+Bit3 (ESC Sport), in my case:
08... Coding
Front Sensor Camera Heating active/instaled
Byte8 Bit0... enable.
10... Coding
Directional Stabilization Assist with Power Steering Asssitance active
Byte3 Bit5... enable.
13... Coding
2B0067C119FFC728949C810560400600000000000000000004
NOTE1: Front_camera: installed
Byte3 Bit6... enable ... + A5 radar interface active (NOTE2).
17... Coding
Lane Maintenance Assist installed
Byte4 Bit6... enable.
Traffic Sign Recognition installed
Byte5 Bit2... enable.
Lane Maintenance Assist Information (BAP) installed/active
Bit11 Bit1... enable. (AID: Lane Assist menu)
4B... Coding, in my case:
Basic setting required!
5F... Coding
Traffic Sign Display (VZA) active
Byte24 Bit6... enable
A5... Coding, in my case:
000307000000040100221354C146A90094000E33004000
NOTE2: Radar interface active.
Byte14 Bit0... enable ... + 13 Front_camera: installed.
NOTE3:
My 3C modules don't support SWA, so I don't code SWA in A5.
ADAPTATION
... from FLA Basic to DLA ...
19
GW installation list: Remove 20, add A5.
09 Cent Elect
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
5F
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,64
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
A5
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10872-Warning intensity: lane depart. warning,Selection via menu ,1
IDE10873-BAP personalization,activated ,1
I extract the NOTES here:
13... Coding
NOTE3:
My 3C modules don't support SWA, so I don't code SWA in A5. 'PR-codes'
Communication between 13 and A5 (NOTES 1 & 2) must be coded at the same time, otherwise you will get faults when coding each module.
I make this comment for those who don't have it coded correctly ...🤭
New VCDS Autoscan!
Wednesday,12,May,2021,06:44:56:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: DLA TEST OK!
Mileage: 35863km-22284mi   Repair Order:
          D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 35863km-22284miles
   Revision: D7H20000
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 06A8DD
   Alarm horn:
   Coding: 0271167841
   Coding: 2B0067C119FFC728949C810560400600000000000000000004
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: 2CFFFF
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
   Coding: 000307000000040100221354C146A90094000E33004000
End----------(Elapsed Time: 01:38, VBatt start/end: 12.4V/12.3V)-----------
Works like a charm!!! :lol:
Drives: Polo 6R 1.2 TDI
Congratulations on a great mod and, as always, a great write up!
Thank you very much Michel 👍, trying the best for those who read this thread.
Well, I found a video on youtube with good and somewhat funny comments in which you can see how the DLA works, just like in my wife's Golf.
+ https://youtu.be/Mqqws2Xde7Y?t=641
Although it is sometimes difficult to appreciate the dance of lights in the video, it is really how he describes it.
Those who already know how these systems work will see it clearly. :wink:
e-Golf 2020, DLA. Factory coding :arrow: https://forums.ross-tech.com/index.php?threads/22636/ 8)
I have coded my 4B module similarly to find out how the headlights behave with factory coding.
Coding: 00000005090016C200205F43020000000000000000000000000000000000
After the tests, everything works very well. (awesome)
The reaction of the camera/headlights to traffic circumstances is surprisingly fast 💎, ... IMHO the left LED headlight (Golf LHD) should react a little faster when it returns to the center position, I speak in terms of milliseconds ... 😂
I confirm this operation:
General information.
Static Cornering Lights (SCLs) or intersection lights. LED headlights.
With 8IX and 8IU LED headlights we have the Dynamic Cornering Lights (DCLs),
which make the light beams of the headlights (LB & HB) move as we move the steering wheel according to the route/path. 8)
LED headlights also have SCLs built into them that have the same mission as SCLs in fog lights.
viewtopic.php?p=577599#p577599
SCLs 'PLUS' 🤭. TEST.
If your Golf has a navigation system, LED headlights with SCLs, and fog lights with SCLs, I recommend that the SCLs remain activated on both sides.
-SCLs in fog lights, BCM adaptation.
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
-In module 4B we activate the predictive SCLs. SCLs in headlights.
-In the BCM adaptions we configure the SCL in this way (my settings).
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,65 °,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,60.0 km/h,16
Test:
At night, we go to take a ride in the direction of a roundabout to test this combination of lights:
-Just a few moments before entering the roundabout with the vehicle,
the SCLs of the LED headlights are turned on thanks to the predictive system,
which is perfect to illuminate the access to the roundabout,
but we note that these SCLs are not enough to illuminate the edges of the roundabout with total clarity.
-When we start to turn inside the roundabout, the SCLs of the fog lights come on,
perfectly defining the edges of those gigantic roundabouts and therefore the trajectory to follow.
On my wife's golf I have LED lamps (with control unit) installed in the fog lights, which provide excellent illumination.
viewtopic.php?p=555624#p555624
My opinion:
With this combination of SCLs we achieve a very good lighting in roundabouts, intersections, garages, underground parking lots, etc.
Note regarding some DLA tests:
The DLA in my wife's Golf is activated (from HB-A white icon to HB-A blue icon) as soon as 60 km/h are exceeded,
it remains that way most of the time, it does not matter the oncoming traffic or in the same direction,
the preference is that the DLA is active (blue icon), ... but I wonder why at 60 km/h, it seems to me that in the Golf8 it is set from 30km/h. https://www.youtube.com/watch?v=pK_SU6g0Nbw&t=369s
Last adjustment in 4B coding. A5 OKAY. (DLA TESTS)
Tuesday,18,May,2021,13:50:28:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: Last adjustment in 4B coding. A5 OKAY. (DLA TESTS)
Mileage: 36166km-22472mi   Repair Order:
          D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 36166km-22472miles
   Revision: D7H20000
Readiness: 1110 0001
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 06A8DD
   Alarm horn:
   Coding: 0271167841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: 2CFFFF
   Coding: 02011103
   Coding: 020111
   Coding: 010000
   Coding: 931F0000
   Coding: 00000005090016C200205F03020000000000000000000000000000000000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:40, VBatt start/end: 14.6V/14.6V)-----------
As you already know, every time the 4B (FCM) coding is modified, it is necessary to carry out the Basic Settings.
With VCDS it is like this:
Ignition ON, engine OFF.
This is the adjustment pattern for 8IU LED headlights with DLA.
I made this adjustment with an electronic regloscope, eventually you can use the 10 meter wall method (verified when I took the image above :)).
We clear the previous faults and recheck that there are no faults.
We verify it in the instrument cluster and infotainment system.
Repeat the procedure in case the faults have not gone away.
Photos instead of screenshots ... 🐒 :mrgreen:
danikd
Drives: Citigo
Post by danikd »
HI Ciclo, waht 10 metres method? Car leveled and wall exactly 10 meter away? Where is this method writen? Thx for info. Daniel
