Modifications to Volkswagen Tiguan
avstuning
Drives: Polo 6R
Post by avstuning »
Hello,
I have a Volkswagen Tiguan
I have decided to upgrade it with the following.
Adaptive Cruise Control (ACC)
Night Vision
Dynamic Chassis Control (DCC)
360 View Camera
Park Lane Assist (PLA)
Virtual Cockpit
Matrix Headlights
High Beam Assist (HBA)
Ambient Lighting 30 Colour
Heads Up Display (HUD)
I need help from the fellow members and the experts @Ciclo @iichel
I need help from start to end. Like where to source the parts, how to fit them, what other chnges required to the car, what coding is required.
I have Original VCDS, Vag Can Pro and a VAS Dongle without ODIS.
Wednesday,23,October,2019,15:30:10:58997
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVGH175NZJA000106   License Plate:
Mileage: 50513km-31387mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 36 42 44 52 55 5F 65
          6C 6D BB BC CA
VIN: WVGH175NZJA000106   Mileage: 50513km-31387miles
05-Acc/Start Auth. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRFD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 CK    HW: 04L 907 309 T
   Component: R4 2.0l TDI   H24 3046
   Revision: B7H24---
   Coding: 0125011203261C003000
   Shop #: WSC 33361 790 00000
   ASAM Dataset: EV_ECM20TDI01104L906026CK 004002
   ROD: EV_ECM20TDI01104L906026CK_004.rod
   VCID: 75A201B8D42743E784-8020
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2011
   Revision: 00H06V07
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW37.rod
   VCID: 3326FFA09AD31DD76A-8066
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 60877000001006
   Coding: 0AEE929A34200B6C4778070062C94950492CD0E2E046923D20605008420A4200002F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
   VCID: 78BC088CC3353E8F9F-802C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0444284120
   Coding: 132C2C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 3E30DE94A191C0BF95-806A
   Sensor Controlled Power Rear Lid:
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98184005
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00511619
   Coding: 0012012410210000000510001010142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4AD88244ED597C1F39-801E
   Relative humidity sensor in fresh air intake duct:
   Rear Climatronic Operating And Display Unit:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
1 Fault Found:
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 105
                    Mileage: 50355 km
                    Date: 2019.10.18
                    Time: 22:23:34
                    Outside air temperature: 33.0 °C
                    Voltage terminal 30: 13.6 V
                    System run time-Engine running time: 253 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: Clean air
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001714601895
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 095A7D48A8DF3707F0-805C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 170521  033 0372
   Serial number: 00000001705170301401
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S5Y17M06D16H06M35S23
   Coding: 00A8DD
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 3Q0 919 294 B    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0029
   Serial number: 001306177478021
   Coding: 0071551011
   ASAM Dataset: EV_EPHBO18VW3260000 007018
   ROD: EV_EPHBO18VW3260000_007.rod
   VCID: 383CC88C83B5FE8F5F-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR33PDMU
   Coding: 88CCC0000C000000400000CF008800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
   ROD: EV_AirbaVW20SMEVW37X.rod
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 106 17
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000799F8152S
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 106 17
   Component: SideSensor_Pf  001 0887
   Serial number: 35800000000F89F8152-
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 106 17
   Component: SideSensor_Dr  000 6149
   Serial number: 3510001B324A4315774S
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 106 17
   Component: SideSensor_Pr  000 6149
   Serial number: 35200019924A4312A75Y
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 005 17
   Component: FrontSensor_D  000 6149
   Serial number: 3550001B724A4311859-
   Coding: 2D2D2D
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 906 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BD25DA8B1944I
   Coding: 2D2D2D
   Pedestrian Protection Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 906 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001BD25DA8B33119
   Coding: 2D2D2D
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 906 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001BD25DA8B212EC
   Coding: 2D2D2D
   Pedestrian Protection Driver 2:
   Subsystem 9 - Part No SW: -----------    HW: 480 000 606 17
   Component: PedPSensor_D2  001 0887
   Serial number: I0M0000000003989252Z
   Coding: 2D2D2D
   Pedestrian Protection Passenger 2:
   Subsystem 10 - Part No SW: -----------    HW: 480 000 606 17
   Component: PedPSensor_P2  001 0887
   Serial number: I0N00000000E29892526
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF034034    Serial number: 20170613501193
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04446C7C8FFD6A6F83-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5NA 920 751 B    HW: 5NA 920 751 B
   Component: KOMBI         302 0310
   Coding: 27A400982A80000801082B041401000000000000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 26051710801771
   Coding: 0105000810087300FB0722081E0F00000001070000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF.rod
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1561717583001384AN1B
   Coding: 290000
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00002.05.17
   Coding: 0101
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000144699009
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA35A8A04F6FC758-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QF612977
   Coding: 0014000000000400018281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3C34D49CB78DD2AFBB-8068
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 100617EF910036
   Coding: 003F1B20D201040000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43C6AF60CA73AD57FA-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8102
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C2B178C4479367D4-8010
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 280417EDS00343
   Coding: 003F1120DE01040000001000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42C8AA64D569A45FF1-8016
Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 086E000009000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB.rod
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      721 0842
   Serial number:
   Coding: 02730600FF00000051110001001828001F0500C60120010003
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D12E9D87CF74B273C-8078
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT1800347
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000054340
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3424FCBC9FDD1AEF73-8060
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Coding: 0123060122002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 393ACD88B8BFE787A0-806C
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31388849000000
   Coding: 0A28
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW37.rod
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 040417ED130454
   Coding: 002A11200100040000001000
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 040417ED130455
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 108040732602
   ASAM Dataset: EV_SunRoofCONTIAU736 006008
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D32D998AC97DBA78C-8068
End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.4V)-----------
Drives: 6R Rline/G7.5/Touareg Rline'19/T-Cr'20
Re: Modifications to Volkswagen Tiguan
There are many of those modifications that are possible. Some of them need to be activated and registered on VW servers through activation codes that you will have to pay.
These activation codes are not available for all countries, e.g, in my VW dealer they don't know what the hell is that about SWaP, FeC, etc ... omfg! :lol:
Even on the VW website for Spain regarding after-sales service and accessories there is no catalog for these activations. Here in stone age, as always. :mrgreen:
I think your best option is to inquire into many threads of the www.drive2.ru forum.
There are stores in Drive2 that can activate some functions (legally) through a remote connection.
This is all the help I can give you. Good luck!
Drives: Polo 6R 1.2 TDI
A lot of retrofits will come to three elements:
Hardware
Wiring
Coding
Sourcing parts will require a thorough study of the parts catalogue (i.e. ifinterface). Keep in mind that retrofits can require existing parts to be replaced as well. You can buy new parts from the dealer or used parts from ebay, allegro, etc.
Wiring can be found in Erwin from VW (buy one hour, save to pdf). Study your current and future configurations.
With the arrival of the mqb chassis, a lot of the coding has received another dimension: SWaP (software as a product). This means you can buy the feature from VW and they code it via a FeC (feature enabling code). This often needs to be done next to the normal vcds coding (bits, bytes and adaptation channels).
Another complication of the new software concept is the so called component protection. This is another safety process to limit the use of used (stolen) parts. Parts like radio or acc radar need to be activated by the dealer to work.
I don't know any of the specifics of your retrofits. Like ciclo, I know some of them have been done before. It will likely not be easy, it still require long study of the Tiguan, it's electrics and it's codings.
iichel wrote: Fri Feb 21, 2020 10:27 am Another complication of the new software concept is the so called component protection. This is another safety process to limit the use of used (stolen) parts. Parts like radio or acc radar need to be activated by the dealer to work.
VW's argument is to prevent theft of parts, but that's not the real reason ...
Unfortunately all humanity is living the worst of the tyrannies ever exercised (the third stupid world war, at the moment hidden). It seems that nobody is interested in these matters related to the personal data proteccion, or who speaks about it has an aluminum foil on the head ...🤪
Fortunately this tyranny can be permanently deceived. The tyrant always thinks that slaves are trained and complacent, ...wrong thoughts... 😁
I agree about the reason, its' more likely VW wants to limit retrofitting and keep control of the products in their cars.
I heard the Golf 8 even has access limited to certain modules, you cannot access them without Gecko authorization code (i.e. 15 Airbags, 5F radio). A real shame and perhaps the end of 'easy' retrofitting. A big shame, it was a major reason for me to love VW the way I love them.
Whatever the reason, it is a clear invitation to hack all 'their' cars.
As it is currently done ... :mrgreen:
I don't see any crime in hacking all the modules of a car that is 'my' property.
