I am getting the engine cutting out whenever I disengage the clutch if the revs are over 1000.
having trawled this site for the fault I learned of the temp sender problem and ordered a got a replacement.
I have a '97 LHD 1.4 8v and the temp sender they sourced for me (from the Chassis number) had a blue ring. The one I took off the car was green.
Replacing it has made absolutely no difference
So I guess I am down to cleaning the throttle bodies. That is unless any of you guys have any better ideas.
Is the throttle body job one I can do myself?
Also the driver door (LHD) key barrel stopped working... on looking inside the door it was missing. Is this a simple replacement or should I take it into a dealer?
Cheers guys.
Jase
