Page 7 of 7
Posted: Tue Aug 26, 2008 11:58 pm
by joannavwdiva
I had the very same problem on the passenger side. I took the door panel off etc etc and the actual clip that holds the glass in place whilst in motion had come off, so if you can imagine, one side is working and the others not, its making the window go up at a slight tilt making it slower and sound slightly painful, i just clipped it back on and all is fine.....just dont slam my door so hard
Posted: Wed Aug 27, 2008 1:51 pm
by randomage
my drivers window has a slightly buggered clip, so the window gradually coems loose, and it gets slower and slower and every couple of weeks it stops. ive just taken to carrying a screwdriver with me, and whipping the card off and clipping it back in every now and then. done it so often now that it only takes about 5 minutes!!!!
Posted: Thu Sep 04, 2008 11:37 pm
by Rupie
That was exactly what ws wrong with mine, was going to do a guide when i fixed mine but never got round to it.
my clip had half sheared off, so i just araldited the plastic clip into the metal hole. works a treat and seems to have fully solved the problem
Re: Power windows died on your Mk4? Read here.
Posted: Thu Jan 08, 2009 5:31 pm
by solidsponge
I totally rebuilt my front drivers electric window and Im proud of doing so!
Its not that hard, just takes a lot of thinking and determination! I bought the entire frame for about £68 and took off the old frame, put the new one on, took the window out mind you. I used the haynes manual, although you dont need it really as long as you can understand how it works you can put it on and hope for the best.
Thought id already said I did it, but cant see post.
Anyone thinking of doing it, its not that difficult to do, took me a few hours.
Posted: Mon May 25, 2009 2:03 am
by luch-polo1.4
I had the same problem with my polo today. it was getting slopw over last few days n today packed up took 3 attempts . will repair kit help me?
Posted: Mon Jun 15, 2009 10:15 pm
by stevopolo
my left window died on me so i thought i would replace the regulator.i went to a scrap yard to get two used ones from him, he tried to charge me £300 including the vat, i thought it was a bit steep so i tried a local auto factors and i was pleasantly suprsied at the price, it was a Magnetti Marelli unit and it cost me a total of £67. Not a bad saving considering the 2nd hand units would of cost me 300 sheets!!! Quick tip people,dont always assume vehicle breakers and scrap yards are cheaper than buying brand new!!!
stevo
Posted: Fri Mar 19, 2010 7:07 pm
by flex
Hay all i do no another whaey to fix the windows if eney one needs to no mine was pasinger side and was stuck up you can get to the moter with the window up sorry for the spelling
Posted: Sun Mar 21, 2010 9:30 pm
by splitstar
yep uv'd guessed it, my electric windows have stoped working...well they work a bit then stop so i tried lubbing it all up which made no difference so im guessing i need the part which is mentioned at the start of the thread. im just wondering where i can get them from, is there any where local in warrington or do i have to order them? and where from and how much?
many thnx
Posted: Sun Mar 21, 2010 9:48 pm
by Ben17
Reading through this entire thread has helped me figure out why my damn passenger window keeps thinking its home is at the bottom of my bloody door.
Stupid clips.
Re:
Posted: Tue Apr 06, 2010 5:22 pm
by Ben17
Very helpful post. This is what I've done.
