Story is that the car ran out of petrol (fuel gauge not working), someone brought diesel which was poured into the tank and and the car was attempted to be started. Diesel was drained off, petrol put into the tank but the car has not started again. A new starter motor and plugs have been fitted without success, the battery has been flattened, probbaly more than once. I bought the car knowing this was the problem.
First thing I did was to run a scan and got lots of codes. Cleared them and rescanned - this time there were a number of immobilisor codes, but before diving into that area I decided to do some basic checks.
- Removed a single spark plug and checked for spark - very bright and strong
Removed the fuel rail and watched for fuel from each injector - one looked weak so I removed and cleaned with carb cleaner / compressed air, now better
Having worked through the Immo codes I have checked that the ECU resistance between pins 20 and 21 is correct and reset to default the ECU to re-read the key. I now no longer have any Immo error codes.
The car does not attempt to fire, my recollection is that if there is an immo problem the car will fire and start but will cut out after a couple of seconds (is it spark or fuel that is cut ?)
I am now thinking it may be something more basic, some potential ideas
- Check plug leads are correctly connected to the coil pack so that the spark is at the right cylinder
make sure all 4 plugs are firing in sequence
Use timing light to make sure No. 1 is firing around TDC (as check for crank position sensor)
