New 2018 Polo GTI faults
- Drives: 2019 Polo GTi Mk 6
Re: New 2018 Polo GTI faults
Hi, my 2019 Polo GTi, has squeaking rear suspension, I took it the the dealership they took it out on nice smooth flat roads, and could not find anything wrong with it, having owned it now for two years I have found the squeaking rear suspension goes away in the winter, may be the suspension is getting lubricated with water, and it the squeaking rear suspension comes back in the summer when the reaches 26 degrees C and squeaks till winter.
Also recently I had a warning come up on the dash board saying check coolant refer to handbook, I had to put in 350 mls of water in the expansion tank, I can’t find any leaks or white gunge in the oil filler cap, it’s gone down a bit more since I topped it up.
Has anybody else had these problems.
- Drives: Polo GTI+
I took my car in for knocking rear suspension last week. They had the car in all day and gave it back to me telling me they couldn't find the issue. I have learnt VW are a waste of time.Richard kinver wrote: ↑Thu Apr 15, 2021 9:03 pm Hi, my 2019 Polo GTi, has squeaking rear suspension, I took it the the dealership they took it out on nice smooth flat roads, and could not find anything wrong with it, having owned it now for two years I have found the squeaking rear suspension goes away in the winter, may be the suspension is getting lubricated with water, and it the squeaking rear suspension comes back in the summer when the reaches 26 degrees C and squeaks till winter.
- Drives: 2018 AW GTI
This is a very common complaint. As I understand I am one of the very lucky ones not having this problem. In the Netherlands some have resolved the issue by having placed some demper at the breaking disks.
This is what you'll need: 2x 2Q0615413 trillingsdemper en 2x WHT010011 spec. boutje
And this what it looks like:
@Richard kinver; If you Google ‘mk7 and mk7.5 golf leaking thermostat housing and water pump failure’ you’ll see this is a cause of coolant loss (and quite common) with the Golf GTI and R models which also have a version of the 2.0 EA888 petrol engine. With the Golf, there have been cases where there aren’t any visible signs of a leak.
Have you had the dealer pressure test your car’s cooling system? Are you able to smell coolant when the engine’s hot and the cooling system is up to pressure? Replacing the thermostat housing / water pump is a quite an expensive job (I’ve seen figures of £750+ quoted on forums for the Golf), so I’d be getting the dealer to investigate whether or not this is the cause of the coolant level drop in your car. At least that way if this is the issue, there’ll be a record on VW’s system to show that this problem occurred within the warranty period so you shouldn’t have to pay for it to be replaced.
@Rosinfield; the issue that @Richard kinver and @Stuart_Rendall have seems to be squeaking / knocking rear suspension, rather than the moo-ing noise from the rear brakes, although it’s possible that they also have that issue with their cars too. On the subject of moo-ing rear brakes, it seems to have gone very quiet on the forum on this issue considering the number of forum members whose GTI’s had this issue. I’m wondering if it’s just stopped happening, if owners have just learned to live with it or if they’ve had the dampers / weights fitted to their rear brake assemblies?
- Drives: Polo GTI+
My rear brakes still moo too but i've learnt to live with it since I took it to VW during my service and they blatantly ignored it on their test drive and said they couldn't find that issue either, even though after watching my dashcam footage back the moo-ing could be heard as well as the tech clearly identifying the issue but not being arsed to sort it.SRGTD wrote: ↑Fri Apr 16, 2021 7:38 am @Rosinfield; the issue that @Richard kinver and @Stuart_Rendall have seems to be squeaking / knocking rear suspension, rather than the moo-ing noise from the rear brakes, although it’s possible that they also have that issue with their cars too. On the subject of moo-ing rear brakes, it seems to have gone very quiet on the forum on this issue considering the number of forum members whose GTI’s had this issue. I’m wondering if it’s just stopped happening, if owners have just learned to live with it or if they’ve had the dampers / weights fitted to their rear brake assemblies?
- Drives: 2020 polo gti plus
Interestingly, my brakes have stopped mooing. I noticed the other day suddenly that I no longer had the loud noise on reverse. I haven’t done anything at all to the car other than started cleaning the callipers when washing the car with some mild wheel cleaner, a hogs hair brush then some brake cleaner when dry. Haven’t had the moo since I started doing this, thinking back.
Weird you should mention that.lancslad1985 wrote: ↑Fri Apr 16, 2021 4:09 pm Interestingly, my brakes have stopped mooing. I noticed the other day suddenly that I no longer had the loud noise on reverse. I haven’t done anything at all to the car other than started cleaning the callipers when washing the car with some mild wheel cleaner, a hogs hair brush then some brake cleaner when dry. Haven’t had the moo since I started doing this, thinking back.
I've started washing the cars with snowfoam (my new toy), and gave my calipers a good going over with snowfoam and a brush the other day.
Only bits I could access, no wheels off or anything.
Anyway, since doing this the mooing is greatly reduced.
Not gone entirely, but not disturb-any-sleeping-neighbours loud any more.
Weird you should mention that.Andy Beats wrote: ↑Fri Apr 16, 2021 4:56 pm [quote=lancslad1985 post_id=582013 time=<a href="tel:1618585774">1618585774</a> user_id=15903]
[/quote]
Yeah it’s only the bits I can get at, I don’t take the wheels off or anything. Since I started doing that two/three washes ago the mooing seems to have gone.
I’ve been quite fortunate or lucky on the subject of moo-ing brakes.
@lancslad1985 and @Andy Beats; like both of you, I also clean the brake calipers (along with the barrels of the wheels and backs of the wheel spokes) when I wash the car. I have a set of Wheel Woolies which, along with a soft bristled detailing brush means I can get to all the visible parts of the calipers. The only time I experience moo-ing brakes is the first time of using the car after washing it, when that thin layer of surface rust has formed on the brake discs because they get unavoidably wet during the washing process. Doesn’t moo every first use after car washing though - just sometimes.
I do garage my car, so my brake discs stay shiny clean most of the time, so I’ve concluded (maybe incorrectly) that I think the moo-ing is associated with that thin film of rust forming on the discs, which will happen if a car’s parked outside, especially when it’s raining.
- Drives: 2018 POLO GTI
My 2018 polo GTI - is just getting the water pump replaced now due to a small leak (26,000kms) plastic end common to crack apparently?
At least it's straightforward under warranty but hopefully they address the issue with a better replacement part.
First time in ages, no mooing from the brakes as I reversed out of the drive this morning.
Actually felt strange not to hear it.
But then they did moo when I reversed into my space at work
Go figure.......
What I really need to get looked at is the jerkiness of the gearbox just as you come off the brakes.
Sitting at lights, release the brakes, there's a noticeable delay then a jerk as it engages the gear, then another jerk as you apply the throttle.
Go figure.......
- Drives: Polo GTI+
I must admit when I first saw your post stating this I had no idea what you were talking about, but I had my car in at VW this week and I had an auto 1.0 95ps polo and the gears were so smooth. I imagine you are more sensitive to the feeling of the jerks, as I can also now feel it after comparison but at the end of the day its a sport box and a sport engine so VW won't fix a jerky box.Andy Beats wrote: ↑Thu Jun 10, 2021 11:53 am First time in ages, no mooing from the brakes as I reversed out of the drive this morning.
Go figure.......
- Drives: About to order an R Line
I had a similar coolant problem on my 2015 Audi TTS and had to argue for nearly two years for it to be replaced under warranty. Sounds like a similar issue here. The loss was minimal but still a warrantable issue!SRGTD wrote: ↑Fri Apr 16, 2021 7:38 am @Richard kinver; If you Google ‘mk7 and mk7.5 golf leaking thermostat housing and water pump failure’ you’ll see this is a cause of coolant loss (and quite common) with the Golf GTI and R models which also have a version of the 2.0 EA888 petrol engine. With the Golf, there have been cases where there aren’t any visible signs of a leak.
- Drives: R-Line and Gti+
I'm so glad you said this, mine didn't moo for some unknown reason last week and I stopped immediately, thinking something was wrong!! It was only a one off though.Andy Beats wrote: ↑Thu Jun 10, 2021 11:53 am First time in ages, no mooing from the brakes as I reversed out of the drive this morning.
Go figure.......
- Drives: 2020 GTI
I managed to find some shop from which I can order those parts, but before that, do these fit any GTI 2018+? Mine is 2020Rosinfield wrote: ↑Fri Apr 16, 2021 5:50 am This is a very common complaint. As I understand I am one of the very lucky ones not having this problem. In the Netherlands some have resolved the issue by having placed some demper at the breaking disks.
