Hi, guys i had a question the brescia alloys have stock tyre size of 215/40/ R18 Y89
Would the 225/40/ R18 92Y fit the brescia alloys without causing any wheel arch rub or being a problem.
Thanks in advance
From bonneville alloys 17inch to brescia alloys 18inch
- Drives: Polo Beats
- Robint
- Drives: 2018 polo GTI
Re: From bonneville alloys 17inch to brescia alloys 18inch
I have had no issues
- OomStu_ZA
- Drives: 2019 VW Polo GTi
Yup works very well indeed!
Hi, the gap between the 215/45 R18 is very small on the front suspension struts.
So would the 225/40/ R18 not rub on the front suspension struts in comparison to the 215/40/ R18
I'm going to be getting michelin ps4's btw
If you could share some pictures of the tyres and to see how much gap there is would be greatly appreciated
- OomStu_ZA
I have the Michelin PS4 225/40/18 fitted. Not sure about the reference to a 45 profile.MittyAhmed101 wrote: ↑Sat Nov 14, 2020 9:48 am Hi, the gap between the 215/45 R18 is very small on the front suspension struts.
4S not available on 225/40 R18, just PS4. Larger sizes are available in 4S.OomStu_ZA wrote: ↑Sat Nov 14, 2020 5:48 pmI have the Michelin PS4 225/40/18 fitted. Not sure about the reference to a 45 profile.MittyAhmed101 wrote: ↑Sat Nov 14, 2020 9:48 am Hi, the gap between the 215/45 R18 is very small on the front suspension struts.
Thanks guys, going with the 225/40/ R18 92Y michelin pilot sport 4
Hope it fits without being an issue
Hi, guy's I've bought a full set
How did you guys fix the clearance issue in the right rear wheel arch liner being flared out any help
Thanks in advance
Thanks in advance
- OomStu_ZA
Thankfully this wasnt a problem when the tires were fitted.MittyAhmed101 wrote: ↑Fri Nov 27, 2020 8:28 am Hi, guy's I've bought a full set
Thanks in advance
