Dink wrote: Tue Mar 06, 2018 5:49 pm
bit of a revival
but i fitted a unit from a newer model polo.
every thing was working fine (bluetooth was showing connected and also appconnect was working) but it had component protection
I've just got back from getting component protection removed
now bluetooth is not working for audio or telephone and it is now saying appconnect needs a key (bit of a kicker but i was kinda expecting it not to have it to start with)
anyone know why a lot of functions have stopped working after getting component protection removed?
which model unit did you buy? im looking to do the same with my 2015 gti as well
Dink wrote: Fri Jun 08, 2018 5:43 pm
3q0035842b is the unit I went for.
sorry to bombard you with questions
was it just plug and play apart from the CP removal?
any wiring changes needed?
what year car did you get yours from?
did you have to change the head unit as well? ive found one from a 2017 tiguan and the seller has stated i would have to change the head unit
if not did your head unit have the mute or voice button bottom left?
ive been speaking to vw and they have said that it is impossible which has made me skeptical when obviously it can be done since you have done it
JaegerStriker wrote: Sat Jun 09, 2018 11:34 am
The head unit (the unit in the glove box)is the bit that changes the screen can stay as it is.
The unit I got was dated 2017 so a lot newer than my polo.
My screen does have voice bottom left button.
You can plug a unit in to see if it works as you will get full functionality apart you will have no sound. So if can get one cheap enough it is worth going for.
Don't listen to vw as they are not really clued up on retrofit stuff
Thanks mate. Great info
I've found a cheap one just waiting to see if it has the appconnect functionality. Surely all models with that model number should have it so I might just wing it
Ah, so I can get a second hand 3Q0035874A (which seems to have app-connect in it already...) off ebay and get my local specialist to code it in then... Spoke to them - they were a bit hesitant but one of their branches has a guy who's more into this stuff so I guess it's a £200+labour gamble, then. Just worried about things like bluetooth not working, plus I have parking sensors.
To clarify, the FECs are the three letter codes off the car's data sticker? Is that right, or will the ODIS machine log into VW and get it all straight off the VIN or something???
Appconnect will be wiped as your car does not have it to start with.
The FeC codes are to do with what options get switched on in the unit. Odis will check the database as to what your car had from factory (I guess via the vin) and give the ok to the unit to switch back on the original options.
Dink wrote: Sun Mar 11, 2018 3:50 pm
Ahh that's the same company that removed my component protection. I might have to give them a call and see what they say.
I've got a VCDS cable so I've got a copy of the coding of my original unit and the new unit (before and after CP)
Then just compared them and made changes to see if they work.
But the bluetooth I could not get to work so I think there might be a bcm upgrade/update required.
how long did they take to remove the CP and get everything sorted? im booked in with them on thursday
