Major sub problem.
Discuss In Car Entertainment
Mk3 Chris
Major sub problem.
Post by Mk3 Chris »
My sub yesterday stopped working for no reason at all.
I've checked all connections everything seems ok but nothing is going to the sub at all... if I take the connections out the sub and put them to another speaker it works ok, so a signal is being sent.
Any ideas?
dub envy
Moderator
Post by dub envy »
sounds like you killed your sub.
if other speakers work on the amp, thenit aint the amp...
did the sub 'pop' or start smoking at any time??
SpikeyG40
Moderator
Post by SpikeyG40 »
don't really no much about subs, but my friend kept blowing fuses! could it be that, sorry probably not that much help knowing me thats the first thing u checked!
Mk3 Chris
Post by Mk3 Chris »
Took it back to the shop, they checked everything and don't have a clue... they went fukkit... pick another. So i have 2 600w subs now :)
So I recommend A1 when buying sound systems!
Mk3 Chris
Post by Mk3 Chris »
One thing... I have on the amp RCH+ RCH- LCH + and LCH - and will be using it for 2 subs only, what should I do to for bass, I know before I didnt wire one sub per channel, it was wired in a funny way like LSUB+ to LCH+ and LSUB- to RCH- or am I in another world?
How should this be wired to get most bass from the amp, my tweets are coming from the head unit.
KarlM
Post by KarlM »
Most amps are normal label 'sub-out' and will have some form of Bass Boost. if your amp doesnt have this then it isnt really designed to run amps (more a component amp). Your only option is to wire the right sub to the right channel and the left sub to the left channel.
Mk3 Chris
Post by Mk3 Chris »
Oh well... i'll keep it the way it is then.
