town driving with some right footing thats about right, my 1.4 does that. Gets even worse if you have been doing 70mph+ because you at such high revs, or if your doing short stop/start trips.
May well be worth cleaning the engine out with some emissions cleaner and engine cleaner (just stick it in with the fuel and drain your tank..) did wonders for my MK1, i was getting a terrible MPG now i get between 40-65mpg depending if im raggin it or not..
WildChild wrote:May well be worth cleaning the engine out with some emissions cleaner and engine cleaner (just stick it in with the fuel and drain your tank..) did wonders for my MK1, i was getting a terrible MPG now i get between 40-65mpg depending if im raggin it or not..
which ones did you use on your car mate? i used some carb cleaner on mine but didn't seem to make a massive difference really, never seen emissions cleaner
Find:
Petrol Treatment at the bottom of the page (buy this)
and
Clean Burn Emissions Reducer - For Petrol Engines (buy this)
i used these two and they worked a dream..
If it says put in with a full tank.. put a FULL TANK in.. dont skimp.. then take it for a nice long motorway drive and empty it, then refill another tank and put the emissions reducer in - should make a big difference. did for me.
means you can do it on your mobile phone without having to remember a number*
* = but not when youre on a garage forcourt - that's a big no-no.
On the run to and from bvf the derby has averaged around 45mpg! But thats mainly down to going slow due to heavy traffic and it running a tad lean top end.
