[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Those of you with a BMC filter - UK-POLOS.NET - THE VW Polo Forum
How did you remove the piece of plastic that connects the original vw air feed? I want to remove it so i can have my own going into the wing? Pics and step by step would be perfection
The only bolt I had to undo to get the OE airfeed out was under the power steering fluid reservoir. Once this was unclipped the bolt was accessible and the feed came out easy.
LiverpoloGTi wrote:The only bolt I had to undo to get the OE airfeed out was under the power steering fluid reservoir. Once this was unclipped the bolt was accessible and the feed came out easy.
Spot on. Get that bolt out and the original plastic air feed comes right out
That's what I did & then fumbled around for a while getting the new pipe into the oval (ish) hole where the OE airfeed used to be, got there in the end though
