[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 MkIV Petrol Warning Light - UK-POLOS.NET - THE VW Polo Forum
So I decided to drive around until I would either run out of petrol or the light came up. Long story short, i ended up having to walk to a gas station to get some more petrol since the car was dead in the road!!!
After that I was convinced there was no reserve light
You do have a petrol light, but you need to put a bulb in there if you open your tacho (i seriously do not recommend this) You can see the slot for it.
Two screws at the top of the plastic surround, a screw either side of the tacho and then about 8 small screws holding the back of the clocks on, take that off and you can see the bulbs. And yes you will need to unplug the clocks it will reset your clock but not your mileage. Hold the tacho up to the light (with the back off) and you should see where the petrol light is. Put a 12v bulb in the relative slot and bang - you have a petrol light. I haven't tried this yet but i imagine it would work, otherwise why would they put it there go very careful as you can render your clocks completely useless!!!
I've searched for the warning illusive light in the manual when I got mine too, doesn't mention it. Anyway, let us know how you get on, might try myself then
I don't think any mk4's before 1997 with the older style clocks have a warning light, i've had two and never seen any lights even when running on fumes
CraigMK4 wrote:You do have a petrol light, but you need to put a bulb in there if you open your tacho (i seriously do not recommend this) You can see the slot for it.
But did you check if where the bulb fits there's a electrical connection? Because it needs a wire to tell the bulb when to light up. And if that's not pre-fitted I wouldn't know where to get it.
But I've grown accustomed of checking the dial when it's in the red zone! 70 km still to go from that point to a complete stall!
Although I don't think polo's have them I've always wondered why when everything else of that age does. I've become customed to resetting the trip computer and waiting for 240miles from a full tank before thinking of re-fuelling!
